10mm square drain plug key
  • helijohn
19 Apr 2014 21:04 #112654 by helijohn
Replied by helijohn on topic 10mm square drain plug key
steffan wrote: Get some solid bar and grind square until it fits nice and tight
This sounds like a good way if you can grind it accurately.
I found the socket extension to be a poor fit and if the plug was once done up tightly by a previous owner or chain store mechanic it can be a pig to shift.
19 Apr 2014 22:18 #112672 by Busta
Replied by Busta on topic 10mm square drain plug key
Its funny how people always over-tighten sump/drain plugs. All the plug does is stop the warm oil running out. I wonder how tight they'd do a coke bottle? Or thermos flask?
  • jonesyba420
20 Apr 2014 09:43 #112705 by jonesyba420
Replied by jonesyba420 on topic 10mm square drain plug key
never had an issue using a 3/8 socket on my diffs, apply pressure so it cant slip out and its fine. i do them up finger tight then just nip them with the ratchet ;)
they do not need to be FT!!!!
  • Yellostreak
20 Apr 2014 09:46 #112706 by Yellostreak
Replied by Yellostreak on topic 10mm square drain plug key
jonesyba420 wrote: never had an issue using a 3/8 socket on my diffs, apply pressure so it cant slip out and its fine. i do them up finger tight then just nip them with the ratchet ;)
Same here... find it helps to pick the mud out first then the usually come out easily.. I put them back in with a bit of PTFE tape that way you don't have to do them too tight..
  • jonesyba420
20 Apr 2014 10:00 #112709 by jonesyba420
Yellostreak wrote: find it helps to pick the mud out first
+1
using a decent ratchet helps aswell not some cheap hellfrauds jobby.
20 Apr 2014 10:09 - 20 Apr 2014 10:09 #112711 by kirkynut
Replied by kirkynut on topic 10mm square drain plug key
Ask my mates how tight I do things up Lol!
I did the brakes on my mates challenge 90 & he bought new wheels. I got a text moaning about how tight the wheel nuts were.
Next thing I know he's had to stop enroute to our club because he'd not tightened his nuts up enough after changing wheels! I don't know!
Use a copper washer on your drain plugs rather than ptfe tape.
Halfords Professional tool range is top quality stuff but if the plug is too tight, like I do them up, even if you clear the mud out, all 3/8 ratchets will round them.
I know, I know, don't do it up so bloody tight, but you change the habit of a life time. It's hard you know!
Last edit: 20 Apr 2014 10:09 by kirkynut.
Time to create page: 0.242 seconds
