10mm square drain plug key
- Thank you received: 77
26 Feb 2014 17:59 #106223
by robs5230
i've now found a 10mm square key
standard jimny - for now
Replied by robs5230 on topic 10mm square drain plug key
the 3/8 does undo the gearbox filler but the tranny box and axle fillers are really FTjonesyba420 wrote: i just hold the 3/8 ratchet head firmly in place so it cant twist out.
the plugs shouldnt be overly tight anyway....................they dont need to be FT!
- jonesyba420
26 Feb 2014 18:03 #106224
by jonesyba420
Replied by jonesyba420 on topic 10mm square drain plug key
I know they can be FT but they shouldnt be, people just go over the top tightening them up. I pop a smear of copper grease on the thread to stop them seizing in to much and just nip them tight.
26 Feb 2014 20:37 #106257
by robs5230
they'll be out somehow. new plugs ordered and picking up tomorrow. if the key and a breaker bar doesn't work i'll weld a bolt on to get em out
17 Apr 2014 05:42 - 17 Apr 2014 05:43 #112399
by Casey
Replied by Casey on topic 10mm square drain plug key
No eBay APP ID and/or Cert ID defined in Kunena configurationThere's this one to, which is a bit cheaper
Last edit: 17 Apr 2014 05:43 by Casey.
17 Apr 2014 06:20 #112401
by robs5230
yeah i had one of those about 18 months ago. it bent. oh and watch out for the britool expert 10mm key ! it isn't 10mm . measures nearly 11mm so no good.
18 Apr 2014 20:42 #112542
by kirkynut
Replied by kirkynut on topic 10mm square drain plug key
I went down exactly the same school of thought and bought a 10mm square socket, then rounded the inside of the filler plug just like a 3/8 ratchet does, so it was a waste of time & money.
I now undo it with a big set of mole grips on the outside and do them up with a 3/8 ratchet. The gearbox and transfer boxes don't mind the 3/8 ratchet and are made of stearner stuff!
Time to create page: 0.264 seconds
