Fan belt/ Alternator belt squeal on start up
  • BensJimny
07 Jan 2014 20:43 #99554 by BensJimny
Replied by BensJimny on topic Fan belt/ Alternator belt squeal on start up
i was always unsure on putting lubricants on rubber belts, i've found a dry bar of soap smeared on the inside of the belt aids movement and to my knowledge doesn't damage the rubber and removes squeaks! give it a try?
  • JimnyKarl
15 Jan 2014 22:57 #100751 by JimnyKarl
Replied by JimnyKarl on topic Fan belt/ Alternator belt squeal on start up
I have the same problem squeal like mad changed both belt still dose it no matter how tight i get the Alternator belt if i slacken the Alternator belt off it stops squealing but then does not charge the battery. i think its the Alternator pulley that is the cause, yes i have tried and exhausted all options so have now ordered a new Alternator. will let you know if that works.
  • ands
28 May 2014 02:09 - 28 May 2014 02:10 #116492 by ands
my jimny also squeaks. already had the alternator and alternator belt adjusted/tightened but still squeaks once in a while. will try to clean the belt and the pulley with soap and water first.
by the way, is it easy to DIY replace the belts?
Last edit: 28 May 2014 02:10 by ands.
  • jonesyba420
28 May 2014 07:06 #116501 by jonesyba420
Replied by jonesyba420 on topic Fan belt/ Alternator belt squeal on start up
Alternator belt is easy power steering belt is abit more difficult.
28 May 2014 16:49 #116528 by maverick
This might help, from Big Jimny "How To" Section, which i always struggle to find :-
www.bigjimny.com/images/documents/changi...er_steering_belt.pdf
Jalapeño, IISY?
  • rexthecat
28 May 2014 18:50 #116543 by rexthecat
Replied by rexthecat on topic Fan belt/ Alternator belt squeal on start up
Draw from the battery putting more on the alternator? Once the battery back to charge squeal goes.
Time to create page: 0.208 seconds
