Fan belt/ Alternator belt squeal on start up
03 Jan 2014 18:58 #98914 by minibbb
My 05 jim has a rather squeaky fan or alternator belt on start up, worse when I have a few electrical things running! Belts look fine and seem nice and tight, could they just need a spray with Wd40 or something?
03 Jan 2014 19:12 #98917 by facade
Make sure the belt is tight: I just go for it is tight enough when I can just twist it 90 degrees.
If that doesn't work, fit a new belt and clean the pulley grooves thoroughly with a wire brush.
Don't use WD40 it damages rubber. In fact dont buy WD40, it is useless except to displace water. For penetrating oil, use diesel or plus gas. The best universal spray in a tin is GT85.
I spray the belt on The Other Car with pledge furniture polish: the silicone stops the squeal, it smells nice too and is only 99p a can B)
One day I will fit a new belt, but you have to dismantle half the car to do it and the pledge is easy to spray from the top ;)
The following user(s) said Thank You: minibbb
  • Fyffe
03 Jan 2014 19:12 #98918 by Fyffe
Possibly alternator or another aux nipping up causing the belts to slip? Try getting someone to start it up with your head under the bonnet to try and localise it if both belts are all in good nick and tensioned correctly?
Jack.
  • rs200boy
03 Jan 2014 19:13 #98919 by rs200boy
Replied by rs200boy on topic Fan belt/ Alternator belt squeal on start up
you will find the belts either need more tension or possibly the rubber has went hard and is squealing over the pulleys and then it needs changed
04 Jan 2014 00:27 #98975 by minibbb
facade wrote: Make sure the belt is tight: I just go for it is tight enough when I can just twist it 90 degrees.
Thanks for the suggestions guys! Shall check the tension again tomorrow but I recall they were pretty damn tight!
I may try the furniture polish trick though!
04 Jan 2014 08:29 #98986 by robs5230
if the belt is squealing but is adjusted properly the its time to change it. spraying stuff on belts is on a par with putting eggs in radiators and tipping thick oil in to quieten noisy motors. old salesmans tricks to pass on dodgy motors.
standard jimny - for now
Time to create page: 0.192 seconds
