how to fix bent radius arm mount.
- jonesyba420
02 Sep 2013 18:17 #81918
by jonesyba420
Replied by jonesyba420 on topic Ive bent it, any ideas?
Cant fit guards with it bent tho. Limited space so you cant really get a good swing as you need to hit it from above.
02 Sep 2013 20:58 #81932
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Ive bent it, any ideas?
Cut the bent bit off and fit guards.
Grey pick up Jimny
- jonesyba420
02 Sep 2013 21:12 #81936
by jonesyba420
Breaking out the grinder will be the last resort
- supergaz
02 Sep 2013 21:17 #81937
by supergaz
Replied by supergaz on topic Ive bent it, any ideas?
I hammered mine back flat no problem, and then fitted guards.
- reaper
02 Sep 2013 21:27 #81940
by reaper
Replied by reaper on topic Ive bent it, any ideas?
Put some chocks round that wheel , undo the arm to chassis bolt and the inner most one on the axle then the arm will drop down pivoting on the outside axle bolt
As said and adustable spanner to bend it then a hammer and block to get it nice n flat
Good work on the bend very neat
- jonesyba420
02 Sep 2013 21:40 #81942
by jonesyba420
Cheers reaper sounds simple enough.do I have to do anything with the lines as they run along the arm?
I do my best to bend things as nicely as possible :laugh:
