Seat belts and air bags?
- srcars
markyp2000 wrote:
srcars wrote:
markyp2000 wrote: If the air bag light is on it fails bt if the air bag light domt work its a pass bt all air bags have to be present or it will fail on them missing
Can I ask how an MOT tester would know if the Air Bags were in the car or not ? I know in the Jimny they are pretty easy to spot but would you get under the dash to check ?
After market steering wheels plus there may be airbag/srs writen on the passenger side of the dash and also may have an air bag turn off key switch and all new cars have them and when looking under the dash at the pedal box and steering collum all air bag wireing is in yellow split tubing
Good points. seemed like a good question when I asked
- Dave cc
Basketcase wrote: It was a brand new one on a test drive the angle of impact mustn't have been right for the bags to deploy or something it's a bit daft tho how they sometimes go off and other times don't plus I imagine one would hurt like hell if it went off! Lol
You are not wrong yeah have a hard bump and then that bloody thing blows up in y face after rippin its way past your fingers i nearly shat myself all these people passing comment get someone to detonate one in your face see how keen you are them then :sick:
- markyp2000
Tits rubbing on the steering that worry me if the air bag goes off even if its a light tap to set it off it may kill them by braking there neck due to the bag coming out as thay go forward
If your seated right you should meet the bag as it up and then you hitting it deflates it
Its a very complex calculation which usually uses a 3-axis gyroscope to determine direction and impact force. If the airbags didn't go off and the driver didn't get hurt then it just wasn't a hard enough impact.
Old airbags are often unreliable, a work colleague recently had an accident in an old Mazda, the airbags didn't deploy but around ten seconds after the impact the airbag warning light started flashing to indicate that a fault had been detected (it wasn't one designed by us!)
markyp2000 wrote: If your seat is in the right position air bags shouldnt hurt apart from the friction burns up ya arm it the women that sit with there
My Mum makes me worry as she is only a little over 4' and as a result drives an auto and sits so close to the wheel. There's not a lot she can do about it, but it does make me thing what you've said every time I see her drive.
- markyp2000
