Trouble with auto hubs/4WD system
samsamsam wrote:
Will they be okay locked in for a few miles on the road between lanes etc? I'm worried about scrubbing my tyres etc?
I am sure I read on here that if you engage 4WD then disconnect the vac pipes that the hubs will stay engaged. I want to permanently engage the front hubs so that the diff doesn't lie idle for months so I am guessing a short distance will be fine but maybe I'll get shot down. I just can't figure out what tubes to mess with. :blush:
I ran my SJ which had manually operated hubs with them engaged all the time cos when I tried jumping out to turn them from freewheeling to fixed I could never shift the things.
- UKDAN
If you have stiff hubs that are hard to turn its because they're full of mud water & old grease, strip them down, totally degrease then reassemble & regrease (I use high temperature white spray grease).
Dan
UKDAN wrote: Found these on eBay the other day might be what you're after 151069547050
Dan
Yes I saw those but I assumed they were just for freewheeling.
- UKDAN
Dan
GuardianAngel wrote: you could apply some Instant Gaskit (you can get this from Halfrauds)
Is there a preferred gasket sealant for this?
UKDAN wrote: I know it says freewheeling but they look like the fixed ones, that you see on other 4x4's (green ovals) & the plastic cups are just covers the same as Jims have on the rear.
Dan
One of the hubs I got off eBay won't freewheel!!
