Trouble with auto hubs/4WD system
  • samsamsam
13 Apr 2013 11:12 #68607 by samsamsam
Trouble with auto hubs/4WD system was created by samsamsam
Hello everyone!
Before posting, I've had a little search around and read up on how the auto hubs work, and I think I've just about got the gist of it. My DIY skills are very limited, but I like to think I could at least understand what the mechanics at my local garage tell me!
Basically I was wondering whether anyone could help narrow down what the issue might be before I spend many millions of pounds on labour fees, seeing as my mechanic is stumped! I have the old 'Flashing 4WD light' issue and I've searched on the forums to find the first checks I have to do. I've checked the hubs and all the pipes and cables etc are still attached. I offroad regularly so it's very possible something got pulled off but I can't see anything obvious. Essentially the vacuum isn't being completed from what I can gather, and there's no 'clack clack' from the hubs either.
The second issue that came on at the same time is that the Jimny won't go into 4WD either. I assume that even if there was a problem with the hubs the truck would go into 4WD? So I'm guessing it would be the solenoids or some other electrical issue affecting the whole system at once?
What I was after was some indication as to what it would be and I could point my mechanic in the right direction seeing as this is a fairly specialised issue. I'm also concerned that if fit manual hubs the 4WD still won't work!
I really appreciate any help anyone is able to give :)
Sam
  • GuardianAngel
13 Apr 2013 21:25 #68644 by GuardianAngel
Replied by GuardianAngel on topic Trouble with auto hubs/4WD system
My vacuum hubs don't make any "clack-clack" noise, but the 4WD still works, so it's not a 100% reliable indicator.
As for manual hubs, it should be fine. All the dials do on the manual hubs it allow you to engage the hub to the drive shaft splines. It removes completely the need for the vacuum system. You are then left with the transfer box to give you the low or high ratios.
  • markyp2000
13 Apr 2013 22:06 #68648 by markyp2000
Replied by markyp2000 on topic Trouble with auto hubs/4WD system
Is it a push button or lever 4x4
  • samsamsam
14 Apr 2013 09:40 - 14 Apr 2013 09:41 #68661 by samsamsam
Replied by samsamsam on topic Trouble with auto hubs/4WD system
GuardianAngel wrote: My vacuum hubs don't make any "clack-clack" noise, but the 4WD still works, so it's not a 100% reliable indicator.
So I guess if I fit the manual hubs and the 4WD still isn't engaging then it narrows down the fault finding process? Is there anything that would affect both the hubs and the 4WD, like a cable or electrical switch that could be broken?
markyp2000 wrote: Is it a push button or lever 4x4
It's a lever, and one I move it into either 4WD high or low it takes about 15 seconds for the light to flash. I still get low ratio gearing, just as far as I can tell (by the amount I was sliding about in the mud!) no 4WD.
I also lifted one of the front wheels off the ground and drove forward with the handbrake on in 4WD and the wheel didn't spin, which if 4WD was working it should have?
Last edit: 14 Apr 2013 09:41 by samsamsam.
  • MWells
14 Apr 2013 10:33 #68671 by MWells
Replied by MWells on topic Trouble with auto hubs/4WD system
samsamsam wrote: It's a lever, and one I move it into either 4WD high or low it takes about 15 seconds for the light to flash. I still get low ratio gearing, just as far as I can tell (by the amount I was sliding about in the mud!) no 4WD.
I've got fixed hubs and my 4wd light takes about that to start flashing.
  • GuardianAngel
14 Apr 2013 10:57 #68673 by GuardianAngel
Replied by GuardianAngel on topic Re: Trouble with auto hubs/4WD system
If you fit MH's then all the transfer box is doing is giving you 2WD high (normal) and 2WD low. There will be no 4WD activation via the 4WD selector. It will be the MH's giving the 2WD to 4WD selection.
Time to create page: 0.148 seconds
