leaking swivel joints
- adamatdraycott
20 Sep 2011 04:30 - 20 Sep 2011 07:40 #22155
by adamatdraycott
Replied by adamatdraycott on topic Re: leaking swivel joints
Mine has now done 47k and they are shot
Never been proper offroading, although i have been laning in it half a dozen times and for a novice they were heavily rutted... but mainly dry.
I live out in the sticks, so the car sees verges and rough tarmac daily.
I've got some decent super thick waterproof grease to use for the bearings, and then smear onto the ball every month or so, to reduce the amount of pitting > hopefully reducing the tearing effect on the seal > reducing water/mud ingress into the bearing housing.
I've heard the large swivel seal should be replaced when servicing. i'm 99% sure the ones fitted is the factory seal, so it has lasted 8-9years.
I'm thinking my wheel bearings will also be close, due to the age and mileage, but that job looks more straight forward and not so messy.
Last edit: 20 Sep 2011 07:40 by adamatdraycott.
- ooky_123
20 Sep 2011 06:01 #22159
by ooky_123
Replied by ooky_123 on topic Re: leaking swivel joints
Our Jimny is now 12 years old.. its done 67,000 miles, of which, the last 7,000 have been done by me ... and its been though some quite extreme terrain / weather conditions.
Since we started to mod the Jimny, we have replaced each wheel bearing once and that is basically it ... This winter though, she will need new Kingpin Bearings, seals and swivel joint seals. I guess weve been lucky because prior to our ownership, it looks like the jimny never left the city.
- adamatdraycott
10 Oct 2011 09:38 #23409
by adamatdraycott
Did mine on Saturday.
The passenger side was far worse than the drivers... infact the drivers had been done not such a long time ago as the pins i took out look new!
The passenger side was fairly bad, with gravel in the grease
Replaced everything... and have 4 kingpins that will be fine to use again!
The new measured exactly 15mm, and the old ones very very slightly under (0.01mm) Will sell if anyone wants some
Plenty of grease in and around the bearings and topped the CV's up too
- chechan rebel
30 Sep 2016 07:26 #173031
by chechan rebel
Replied by chechan rebel on topic Re: leaking swivel joints
Yeah ive just noticed my driver side leaking the other day...... All parts are on the way for a full rebuild both sides, king pins, king pin bearings, wheel bearings, all seals ect...... Anyone know how thick an what sizes those copper shims are?
Time to create page: 0.262 seconds
