New Jimny project - a few questions!
  • X-Eng Simon
22 Jul 2011 21:30 #19368 by X-Eng Simon
New Jimny project - a few questions! was created by X-Eng Simon
We (X-Eng) have bought a Jimny to build something interesting out of it!
Although X-Eng is mostly Land Rover based, we built a comp-truck out of an old Vitara - and I have to admit I've kind of fallen for Suzuki's. A Jimny seemed the obvious choice for the next build - and this seems to be Jimny Central!
The plan is for something completely road legal, but avoiding the requirement for an IVA test but also fully MSA compliant, the combination allowing it to enter any winch Challenge in the UK. My current Suzuki is neither and there's not much it can enter these days.
I have a 1999 Manual Soft Top and it's going to turn in to an auto. I also have Toyota FJ80 Axles and Fox-Air shox and some unorthodox suspension geometry plans.
My first question is, I have a Vitara Auto Box which I plan to fit with the original engine. Has anyone done this? Do the change points in the gearbox match up reasonably with the auto box fitted to Jimny's?
It will get Megasquirt so there is some potential for mapping the engine to the box if not.
I dare say I'll need a bit more advice along the way - and in return, I'll do my best to contribute what I can to the forum.
Si
23 Jul 2011 05:03 - 23 Jul 2011 05:04 #19370 by mlines
Welcome - the only rule here is PICTURES!
I don't know of anyone who has done what is effectively the reverse of what a lot of others have down. They have fitted a Vitara engine to a Jimny Gearbox rather than fit a Jimny Engine to a Vitara Gearbox. I will have to leave this to the others comment apart from asking what engine you have in the Jimny, is it an M series or a G series? This is because you could be making things even more challenging by mating an M series engine to a G Series Auto box.
Certainly mating a G Series Vitara engine to a G Series Jimny Gearbox is reasonably straight forward (in fact, you can use a bodge method of a large drill and some bolts to join the two). But other combinations get more difficult. I would have thought it would be easier to source a Jimny Engine/Autobox or Suzuki Baleno Parts if its an M series set up. My "dream machine" would be to source a Diesel Auto from a European Jimny. I keep being told that due to "scrappage schemes" there are a lot of parts available in Germany, but have yet to get around chasing it up.
Last edit: 23 Jul 2011 05:04 by mlines.
  • X-Eng Simon
23 Jul 2011 06:45 #19377 by X-Eng Simon
Replied by X-Eng Simon on topic Re: New Jimny project - a few questions!
Thanks for the info. Here are some piccies:
My 4 wheel Independent suspension, 4 wheel steer, twist in the middle Vitara:
Attachment Vitara0.jpg not found
Attachment Vitara1.jpg not found
Many more photos here
And my new Jimny - which is going to get a slightly less extreme treatment!
Attachment NewJimny.JPG not found
But it will get the same tyres on Beadlocks on Toyota FJ80 Axles using single-link A frames front & rear so should be just as capable.
How do I tell what series either my Vitara was or the Jimny is?
Si
  • mcjimny
23 Jul 2011 07:06 #19380 by mcjimny
Replied by mcjimny on topic Re: New Jimny project - a few questions!
A name thats been around the scene for years! I'm watching this with great interest.
  • X-Eng Simon
23 Jul 2011 10:07 #19387 by X-Eng Simon
What? Me? I've mostly been on the dark side (Land Rovers) - but have seen the light!
The 1.6 Vitara engine seems to have 19G cast on to the back - so I'm guessing it's a G series?
My reason for doing it this way round is in order to keep the same vehicle identity. Each part of a vehicle has a number of points associated with it:
chassis or body shell = 5 points
suspension = 2 points
axles = 2 points
transmission = 2 points
steering assembly = 2 points
engine = 1 point
And you need to keep 8 points worth to retain the identity.
So, Chassis=5 + Steering = 2 + Engine = 1 => 8 Points
Axles, suspension and transmission all need to change - so I have to keep the engine!
Otherwise, I would just transplant the whole engine & transmission inc twin transfer box conversion into the Jimny.
The twin transfer is important because in high range, the SJ box divides the ratio by 1.6 which means that it's geared about right for 37" tyres. If the Jimny Engine cannot mate to my G series auto-box, I'll have to machine an adaptor so a Jimny Auto can drive the Vitara Transfer box, then in to the SJ.
Where would be a good (read cheap) source for an Auto box?
Si
  • darthloachie
23 Jul 2011 10:19 #19388 by darthloachie
Replied by darthloachie on topic Re: New Jimny project - a few questions!
try cam suzuki - they are jimny breakers - often on ebay
or try the other jimny breakers on ebay
look forward to seeing the build
Time to create page: 0.520 seconds
