New Jimny project - a few questions!
- X-Eng Simon
14 Nov 2011 17:58 - 14 Nov 2011 18:02 #25770
by X-Eng Simon
Si
Replied by X-Eng Simon on topic Re: New Jimny project - a few questions!
Dang! If it wasn't for you pesky kids - I'd have gotten away with it!has the local pub noticed it's missing two pool balls yet
Si
Last edit: 14 Nov 2011 18:02 by X-Eng Simon. Reason: The voices told me to do it
- aniesigh
24 Nov 2011 18:48 #26513
by aniesigh
Replied by aniesigh on topic Re: New Jimny project - a few questions!
any updates Si?
- X-Eng Simon
24 Nov 2011 20:17 #26522
by X-Eng Simon
It's coming along!
Last weekend I fitted the front axle, but discovered the A frame fouled on the prop shaft when the suspension was fully compressed - only a tiny bit, 2mm - but too much.
I re-made the prop shaft using a Land Rover half shaft in-between the two UJ's so the prop went from 55mm to 31mm diameter - and now it works nicely!
Project for this weekend is to make the steering rod and panhard rod then start figuring out where and how the Fox Air shocks will mount.
I needed to move the transfer box a little too to allow a bit more clearance, so I'll have to re-make the mountings again.
Then all I'll have to do is make mounts for the seats, a bit of plumbing & wiring and it will be drivable again!
Si
Si
- Rabid Rhino
- Elite Member
- Thank you received: 33
25 Nov 2011 15:05 #26557
by Rabid Rhino
Replied by Rabid Rhino on topic Re: New Jimny project - a few questions!
T case Doubler ?
Whose kit are you using ?
I have the OTT Industries, Kicker 3 (Vitara to Samurai) in my Vitara
I like it because it bolts the Vit reduction box directly to the sammi t-case. No remote t-case.
I don't know if you can still get their stuff as I thought they sold the business and the buyer has yet to start production.
- X-Eng Simon
25 Nov 2011 16:14 #26565
by X-Eng Simon
I'm using my own!
It's so not rocket science to cobble the two together that buying someone else's kit seemed a waste.
I've been using the setup on my previous truck with good results - so just transplanted it to this build.
Si
Si
- Old Blind Dog
11 Dec 2011 21:48 #27943
by Old Blind Dog
Replied by Old Blind Dog on topic Re: New Jimny project - a few questions!
Si, don't you have any photos of coupling process or can you make some close pics of the twins?
Thinking of combining new grandvitara and jimny button tcases. Going mate it with grandvi autobox and M18A engine.
Thanks
Thanks
Time to create page: 0.170 seconds
