Stuck in 4wd
29 Dec 2018 08:12 #199604 by Scimike
Replied by Scimike on topic Re:Stuck in 4wd
Still stand by my original comment that it sounds like your love for this vehicle has gone and you should sell it and get something else. Its a car, they will go wrong, if you hate it every fault will just wind you up further.
Plenty of good modern vehicles to choose from, but avoid Land Rover and small TDIed engine VWs (I owned both, very expensive to fix).
RAV 4s pre 2000 have a reasonable reliability record, may even be better on rust issues, so possible cheap secondhand option. Newish maybe VW Yeti in 4x4 option?
You need to decide whats best for you and your circumstances , as you say you cant keep throwing money at a rusty unreliable Jimny if that is the case.
Good luck whatever you decide, but I hope you keep it.
  • Mattch5150
29 Dec 2018 08:27 #199606 by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
It is silent, no hiss
29 Dec 2018 11:32 #199618 by jackonlyjack
Replied by jackonlyjack on topic Re:Stuck in 4wd
Fuel leak could be the hose connection from the flap
under the rear arch is a plastic cover pop the clips off and take a look
  • Mattch5150
29 Dec 2018 15:10 #199637 by Mattch5150
Took flap off, I think it is leaking where the pipe comes out of the tank, the pipe with the large jubilee clip on. Plastic studs on flap were toast so cable tied it Back on!. Only leaks when full
  • Mattch5150
29 Dec 2018 15:47 #199639 by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
Put new spark plugs i in today, just bosch nickel ones. The plugs that were in were all in very loose, almost not screwed in at all. 3 plugs the same and one different. Running fine at the moment and my stutter seems to have gone. Btw have posted a pic of the offending jimny as don't think I have before!
29 Dec 2018 17:52 #199667 by Busta
Replied by Busta on topic Stuck in 4wd
Sounds to me like you've just been very unlucky and bought Britain's worst kept Jimny!
I've never heard of the fuel leak issue before, nor broken wires to the transfer case. If the front wheel bearings were gone that would be another cause of the front hubs not working.
Loose spark plugs is entirely the fault of the person that fitted them, again not a reliability issue with the Jimny.
Time to create page: 0.403 seconds
