Fitting your own Bearings
04 Aug 2016 10:44 #170918 by Jezz
Replied by Jezz on topic Fitting your own Bearings
My rear bearing change.
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
It's been fettled just a tad.
04 Aug 2016 10:48 #170919 by X8GGY
Replied by X8GGY on topic Fitting your own Bearings
Where are you shafts from then Jezz? :blink:
04 Aug 2016 10:54 #170920 by Jezz
They are from KAM, No longer available but make changing bearings a doddle.
04 Aug 2016 11:49 #170923 by X8GGY
Shame!
I take it the flanges are off another Zook?
What we need is a machining guru kind of fella that can make shafts?... :whistle:
  • gusthegorilla
04 Aug 2016 16:52 #170925 by gusthegorilla
Replied by gusthegorilla on topic Fitting your own Bearings
facade wrote: I pulled the bearings off the shafts in my gearbox with one of these, (you might get the wheelbearing off with some extra threaded bar, but I doubt if you could pull the bearing and the abs collar at once.)
and pressed it all back together with one of these (mine is a 10 tonne one), I pressed my wheelbearings back on with it too.
Both useful pieces of kit, but you don't exactly need them everyday ;)
Would a press of that type be capable of removing / fitting the one-piece bushes found in the front and rear radius arms ?
  • Daniel30
04 Aug 2016 17:45 #170926 by Daniel30
Replied by Daniel30 on topic Fitting your own Bearings
Yes it would probably help if you find a socket the right size to help push it in more evenly :)
Time to create page: 0.331 seconds
