Fitting your own Bearings
03 Aug 2016 11:08 #170874 by maverick
Who changes their own Wheel Bearings (Rear with an ABS Ring) and Fronts into the Hubs ... AND what do you use??
I'm thinking of investing in a Press - who uses what?
Thanks Brett
Jalapeño, IISY?
03 Aug 2016 15:06 #170878 by X8GGY
Replied by X8GGY on topic Fitting your own Bearings
Martin's guide to front wheel bearings - www.bigjimny.com/mediawiki/index.php/Fro..._Bearing_Replacement
Not sure my missus would like me cooking a hub in her oven though? ;)
Googling the rear bearing and found this thread - www.4x4community.co.za/forum/showthread....-rear-wheel-bearings
Where they mention a similar approach to what my local garage did... (I was chatting to Brett about this this morning when he came over, they stole a length of seamless tube off me and slip that over the shaft to tap the bearing and ABS ring into place)
03 Aug 2016 16:24 #170881 by maverick
Replied by maverick on topic Fitting your own Bearings
I'm sure Lynne won't know if i use the Oven whilst she's at work ...
I have a couple of "spare" Hubs and Bearings on the shelf to have play with.
Also, 33 views and not one comment :( other than YOU Dave :woohoo:
Jalapeño, IISY?
03 Aug 2016 16:33 #170882 by maverick
S200KYS wrote: Googling the rear bearing and found this thread - www.4x4community.co.za/forum/showthread....-rear-wheel-bearings
I don't understand (maybe cos I'm not an mechanical engineer) how the Bottle Jack got the ABS Ring off after they welded a bar onto the bearing?
I had heard that Russell was thinking of making a replace-able ABS ring - one of his "to do" Project.
Jalapeño, IISY?
03 Aug 2016 16:53 #170883 by X8GGY
Like this mate -
Where the BLUE bars are welded to the bearing outer race, and then a bar across the top, then the RED bottle jack is on top of the shaft and jacking up the blue bars to lift the bearing and ABS ring up the shaft...
03 Aug 2016 17:41 #170885 by maverick
doable with the short shaft, not so sure about the long shaft though!
Jalapeño, IISY?
Time to create page: 2.855 seconds
