2 Inch lift advice
  • 1066Boy
22 May 2016 11:20 #167234 by 1066Boy
Replied by 1066Boy on topic 2 Inch lift advice
Busta wrote: 3 inch trial master springs on the front will balance out the weight of the bumper. I think this is what TomDK runs and he knows his stuff when it comes to suspension!
1066, if the suspension is stiff enough to reduce body roll on road it will definitely be reducing the articulation you get off road compared to standard springs.
Articulation is fine offroad. :) I think the main reason for the on road improvement is that the original
springs and dampers were way past there best. :laugh:
22 May 2016 16:30 #167249 by Busta
Replied by Busta on topic 2 Inch lift advice
By fine do you mean worse than standard but still acceptable?
  • 1066Boy
22 May 2016 17:23 #167258 by 1066Boy
Better than standard. Apart from the ground clearance, the firmer springs help to keep
the jimny more under control especially when going down hill at an angle. With a lot of the
weight on one front wheel with the diagonal rear one going a bit light. :)
Hope that makes sense, i dont know how else to describe it. :laugh:
22 May 2016 18:26 #167264 by Busta
That just sounds like stiff suspension. You can't have stiffer springs AND more articulation, and it's articulation that keeps the tyres on the ground, giving you the traction you need to get places.
  • 1066Boy
22 May 2016 18:37 #167269 by 1066Boy
Never said the articulation was better, just good. :P
If you are on a steep decent and have no option but make a turn, the last thing you need
is the vehicle wallowing about on over soft springs.
On the level lots of flex is better for traction, but the places that i go are far from level. :laugh:
22 May 2016 18:51 #167273 by Busta
Sorry, I must have misunderstood!
1066Boy wrote: Articulation is fine offroad. :)
Busta wrote: By fine do you mean worse than standard but still acceptable?
1066Boy wrote: Better than standard.
Your hypothetical situation is not something I've ever witnessed or would consider a priority. A sports car would be best in that situation, but as with everything there is a compromise to be met!
Time to create page: 0.265 seconds
