boot floor rust - again
29 Oct 2015 15:17 #154797
by Keithy
Replied by Keithy on topic boot floor rust - again
When I replaced mine it was raining and all the side panels were removed.....OS rear window was leaking...go figure.
29 Oct 2015 16:48 #154805
This is defo the answer.
Especially if the oxidisation started before the steel was used.
Replied by helijohn on topic boot floor rust - again
mickt wrote: Poor quality steel (Chinese)I fancy!
+1
- Thank you received: 360
31 Oct 2015 14:47 #154949
by Halford
Replied by Halford on topic boot floor rust - again
2 days after painting - it's started already .......... rusty drops
and no it's not dog wee, she hasn't been in the car since it was done, still a mistery where it's from :huh:
31 Oct 2015 15:27 #154957
by BGBrit
Replied by BGBrit on topic boot floor rust - again
I wonder is it from using pressure washers, many people use them after mud runs.. perhaps the mastic seams are dislodged or broken down by them.
BGBrit.
BGBrit.
31 Oct 2015 15:45 #154958
Replied by Daniel30 on topic boot floor rust - again
How about trying that primer/sealer used for painting ships I'll try and find the thread on the forum later
- slew53
31 Oct 2015 16:04 #154960
by slew53
Replied by slew53 on topic boot floor rust - again
What does it look like underneath the bit you are painting? I am not a fan of hammerite it use to be good stuff but was bought out and like so many products does not seem to contain the "good stuff" it once did, the sub frames on my last car I stripped and sprayed with epoxy mastic (brushes on too) and that appears to hold up well and was good as far as not being damaged easily when reassembling things, got it off Ebay Rust busters epoxy mastic. Underneath my Jimny I intend to wait until next summer when hopefully we will have a long hot summer! and I want to wire brush underneath and paint with waxoyl underseal (it is a mix of wax and underseal) then I use a small pump action bottle(like you get for less than £1 to mist plants) with some cavity wax to wax everywhere hoping the wax will creep into all the places not easily seen, unfortunately the only real way to deal with rust is to cut it out and weld new in.
Time to create page: 0.432 seconds
