boot floor rust - again
01 Nov 2015 13:33 #155064 by BGBrit
Replied by BGBrit on topic boot floor rust - again
Yes Halford,, it will help reduce road noise too, I'm thinking of adding to the mat some foam, to reduce the condensation problem further, as I believe Kirkynut has a sound idea there...
  • helijohn
01 Nov 2015 14:59 #155069 by helijohn
Replied by helijohn on topic boot floor rust - again
Halford wrote: Sounds plausible Kirkynut ;)
Maybe it's worse on those with boarded out rears,
might put the carpet back on under the board :huh:
I have this stuff under mine. It breathes so to speak but I put it there as sound deadening TBH.
Originally I bought it for the field to use as a landing pad which wasn't too successful so it became underlay. I have a board on top of it then a carpet.
01 Nov 2015 16:06 #155071 by BGBrit
The main thing is keeping it close to the metal, minimum air space, but not crushed, and it may seem over the top but if foam or thickish material followed the boot metal contours and the foam topped with polythene then topped with carpet to protect the poly it would prevent internal condensation meeting the cooler metal boot floor.. Taping any seams or tears in the poly too would help..
BGBrit...
  • irishguy123
02 Nov 2015 20:01 #155209 by irishguy123
Replied by irishguy123 on topic boot floor rust - again
Daniel30 wrote: How about trying that primer/sealer used for painting ships I'll try and find the thread on the forum later ;)
Do you mean this stuff that I used?
It definitely sets as hard as rock and seems completely impenetrable. But I think if you sealed the top of the boot floor it would still rust out from the bottom where there is loads of joints and seams. Really the only way is to either completely remove the rust underneath and then seal it or just remove the floor all together :unsure:
The sad thing is that the newer Jimnys look to be faring no better than the older ones.
  • Daniel30
02 Nov 2015 20:04 #155211 by Daniel30
Replied by Daniel30 on topic boot floor rust - again
Ahhh ha!!! that's the one ;)
  • helijohn
02 Nov 2015 20:06 #155212 by helijohn
Yet modern cars generally seem to be less prone to rust these days. :whistle:
