stainless exhaust
  • Nicks_Jim
20 Oct 2014 20:23 #127029 by Nicks_Jim
stainless exhaust was created by Nicks_Jim
Hi all, i was just wondering what was everybody thoughts on size of exhaust bore as i'm having a full stainless exhaust made for my m13a jimny, standard size bore or go bigger to 45mm or 50mm Thanks Nick
  • steffan
20 Oct 2014 20:48 #127033 by steffan
Replied by steffan on topic stainless exhaust
I fancy a 2 inch stainless exhaust system
21 Oct 2014 09:02 #127063 by Busta
Replied by Busta on topic stainless exhaust
Anything bigger than a drinking straw should be fine for the 1.3! On a standard engine you won't see any gain in power by going over 40mm. 45mm will give you enough flow for a 1.6/105hp conversion if you go down that route.
Despite what Max Power will tell you, unless you've done lots of engine work the size of exhaust the manufacturer fits is appropriate for the engine. Most 'gains' people perceive are to do with the noise rather than more power.
  • Nicks_Jim
21 Oct 2014 09:31 #127066 by Nicks_Jim
Replied by Nicks_Jim on topic stainless exhaust
MysticRich wrote: I had a 2" stainless system with a decat pipe on and makes a great amount of difference ;)
Getting a complete new system next month made up as I now need a rear stack and having a 4branch this time so carnt wait to see the gains.
Hi, I had a quote for the full system with tubular manifolds, cat, and back box all fitted £600 up to 50mm bore not bad.
Hi Busta, Apparently on a turbo engine it's only the first two foot that makes the different so surely bigger than standard should make a big different. Nick
21 Oct 2014 10:50 - 21 Oct 2014 10:53 #127073 by Busta
Nicks_Jim wrote: Hi Busta, Apparently on a turbo engine it's only the first two foot that makes the different so surely bigger than standard should make a big different. Nick
Is your Jimny turbocharged?
There is an optimum size where the flow of gas through the exhaust is not restricted. Once you go over this size, you will see no gains. For a standard 80hp 1.3 Jimny this is around 40mm.
The catalytic converter is the most restrictive part of the exhaust, so a de-cat will give you the best returns but may make passing the MOT emissions test tricky/expensive ;).
Design of the exhaust manifold (header) can affect the torque and power of an engine, and a well designed manifold can make a difference over a manufacturers 'log' style cast manifold but these gains are likely to be at the top end. In a 4x4, where low end/mid range is most important you are unlikely to gain much if anything in terms of usable power.
Last edit: 21 Oct 2014 10:53 by Busta.
  • Dyl
21 Oct 2014 11:41 #127074 by Dyl
Replied by Dyl on topic stainless exhaust
I need a new back box. Is there a place I can get a replacement in stainless steel?
Time to create page: 0.218 seconds
