Roll cage
  • Bigjim91
31 May 2014 20:59 #116793 by Bigjim91
Roll cage was created by Bigjim91
I've managed to get hold of aload of galvanised scaffold poles, does anyone know is it ok, strong enough, easy to bend, for a roll cage/traybak round my Jim?
  • rhys15
31 May 2014 21:07 #116795 by rhys15
Replied by rhys15 on topic Roll cage
Sacaffold is realy heavy because it is so thick and the galvanised coating has to be ground off for welding, as for bending its designed not to be bent for its purpose thats why its so thick
  • TomDK
31 May 2014 21:12 #116797 by TomDK
Replied by TomDK on topic Roll cage
Bigjim91 wrote: I've managed to get hold of aload of galvanised scaffold poles, does anyone know is it ok, strong enough, easy to bend, for a roll cage/traybak round my Jim?
You'll need to come up with some more details. But in general, no. Not suitable for rollcage use. But if it's just for a simple external cage to protect the body, it's fine. Just not good enough for a cage to protect you and others. For that you'll need CDS tubing 45 x2 mm or T45 tube.
  • steffan
31 May 2014 22:08 #116800 by steffan
Replied by steffan on topic Roll cage
TomDK wrote:
Bigjim91 wrote: I've managed tot hold of aload of galvanised scaf poles, one know is it ok, strong enough, easy to bend, for a roll cage/traybak round my Jim?
Don't fia roll cages need to be 3mm thick that was my understanding it should also have cross braces to prevent twisting
  • Bigjim91
31 May 2014 22:42 #116801 by Bigjim91
Replied by Bigjim91 on topic Roll cage
I bin looking at 42.4mm x 3mm mild steel tube, any good?
  • Dave cc
01 Jun 2014 08:21 #116814 by Dave cc
Replied by Dave cc on topic Roll cage
Any tube can be used but to be msa spec needs to be cds tube or blue band pipe finding the tube is the easy bit although expensive bending and notching it is the difficult part
Time to create page: 1.448 seconds
