winch.. do i or dont i
- ne-crock
10 May 2014 19:18 #114763
by ne-crock
you cant of been that stuck, must of just needed that extra bit off pull to get you moving,
i'd go for atleast 6000lbs but i went for 9500lbs,
if not competing winch speed doesnt really matter, as long as it gets you out,
i went for a goodwinch tds 9.5c really happy with it, also seen one in action on a trip out which included a big recovery job before i purchased mine and it performed fantasticly
Replied by ne-crock on topic winch.. do i or dont i
idiotmobil wrote:
maverick wrote: If you are, and I would always say YES, as its your 'get out of jail card' - then don't get anything less than an 8,000lb winch.
completely disagree with this I used a 3000lb winch doing every thing my 13000lb winch does now and it never failed
- Tommo
10 May 2014 20:38 #114776
by Tommo
Replied by Tommo on topic winch.. do i or dont i
- GuardianAngel
10 May 2014 21:05 #114778
by GuardianAngel
Replied by GuardianAngel on topic winch.. do i or dont i
What about some 5/10 ton ratchet straps? Cheaper and more versatile. Just needs some hard work to get you out of trouble
- idiotmobil
10 May 2014 21:23 #114780
by idiotmobil
ye ive been extremely stuck with it half way up doors in Salisbury plain clay mud and pulled me out with abit of a struggle with no engine to help, also pulled out a Hilux from same sort of situation
the winch is now on the rear of the jimny and pulls my brothers pajero out a lot as he is usually behind me plus can be doubled up with a snatch block then you have 6000lb of pull
Replied by idiotmobil on topic winch.. do i or dont i
- ne-crock
10 May 2014 21:43 #114781
by ne-crock
but a 3000lbs winch is a 1300kg winch pull rate,
a jimny weighs the best part of 1.1 tons plus yourself and other stuff in the car, lets say another 100kg, that gives you 100kg to play with,
when recovering a friends truck i've seen a pile of mud form infront and at a guess from its size it was bigger than 2, 1 tonne bags infront of the truck, that means there would of been no way in hell a 3000lbs winch would pull it even with a snatchblock
it may have worked for you, but its more of a ATV winch rather than a 4x4
in my own opinion 6000lbs minimum and theres no need to go higher than 9500lbs
- idiotmobil
10 May 2014 21:53 #114784
by idiotmobil
im not saying get a 3000lb winch just saying it will and has on many occasions pull a jimny out of anywhere he will get stuck ive been there and done it and wouldn't of stuck in on the rear of the jimny if I didn't trust it to pull me out as ill never drive around any thing so recovery is very important, would be very cheep and light weight for a lanner jimny
Time to create page: 0.153 seconds
