Winch cut of switch location?
24 Mar 2014 16:27 #109878 by kirkynut
You don't want any power cable going anywhere that is not fused or switched, through the bulkhead or not, secured well or not. Given the size of the required live cable to a winch, we generally don't fuse it, so it has to be switched. The solenoid is a type of switch to switch the motor, it doesn't prevent the live that feeds the motor being there.
You're mad if you don't have an isolator on your winch wiring, isolating the live from the battery to the winch. As Mark says, as close to the battery as possible so there is the least amount of cable running a live that isn't switched.
  • jimnydms
24 Mar 2014 17:28 #109899 by jimnydms
Replied by jimnydms on topic Re:Winch cut of switch location?
And in your opinion the sw60 albright solenoid isn't sufficient to isolate the live when not being used ? Not a trick question just so I know. As I am wiring my set up on the advice of another member ?
  • S Mark
24 Mar 2014 18:54 #109912 by S Mark
Replied by S Mark on topic Winch cut of switch location?
I completely understand where your coming from Kirknut that's why I have been working on this before I connect to the battery, as a fail safe.
But I wil be putting another Albright solenoid type, that can cut the main feed to the winch via a 5amp switch on the dash. My winch also came with a big fuse which will also be in the equation.
24 Mar 2014 21:50 #109954 by kirkynut
jimnydms wrote: And in your opinion the sw60 albright solenoid isn't sufficient to isolate the live when not being used ? Not a trick question just so I know. As I am wiring my set up on the advice of another member ?
No, if water gets in to to Allbright or switches etc, or the Allbright goes wrong, the winch will operate by it's self. It happened to a friend during the break at a challenge event and the winch pulled his car apart and crushed his cage (made from woefully thin tube). So it happens. Not if it's isolated & off and neither can an elecetrickery fire if there's no elecetrickery!
24 Mar 2014 21:51 #109955 by kirkynut
S Mark wrote: I completely understand where your coming from Kirknut that's why I have been working on this before I connect to the battery, as a fail safe.
That's good.
Time to create page: 6.727 seconds
