Winch cut of switch location?
  • jimnydms
24 Mar 2014 11:01 #109855 by jimnydms
Replied by jimnydms on topic Re:Winch cut of switch location?
You do away with a normal manual isolator and have the solenoid in line insted and is operated by a switch in cab. This was my preferred way and not that expensive. A cheap switch on off switch with a led £5 and the solenoid was 30£ off eBay.
  • jimnydms
24 Mar 2014 11:05 #109857 by jimnydms
bit.ly/1gt3BRB that's the kind of thing you need I can take a pic of mine later
  • S Mark
24 Mar 2014 12:58 #109862 by S Mark
Replied by S Mark on topic Winch cut of switch location?
That was the exact Albright switch I put in my watch list after your first poast. A picture would be exelant, I have had good practice wiring relays so it should be a walk in the park to do.
24 Mar 2014 15:50 #109874 by kirkynut
You do need to be able to cut the power to the winch aswell as the solenoid. Imaging if your heavy winch power supply cable were to rub through somewhere & ground out! If you were not with it or couldn't switch it off the fireworks would spell the end of your Jimjam and you'd be claiming for a burnt out car along with whatever else it burnt or damaged that was nearby.
Some people fuse it but it's not usual due to the size of the fuse so it must be switched.
  • jimnydms
24 Mar 2014 16:19 #109875 by jimnydms
Doing it this way Kirkynut your not running any high powered cables through bulk head etc. they are just run in engine bay secured correctly. Then you have a 5amp signal from a switch in can to the solenoid. That's powered by a fused positive direct from the battery. I can't see you d need another manual isolator ?
  • jimnydms
24 Mar 2014 16:20 #109876 by jimnydms
Maybe I have mis understood your post actualy re reading
Time to create page: 2.315 seconds
