Petrol tank breather
  • Chazg83
15 Feb 2014 15:14 #104590 by Chazg83
Replied by Chazg83 on topic Petrol tank breather
Cheers for all the info guys I do appreciate it all
15 Feb 2014 15:14 #104591 by mlines
Replied by mlines on topic Re:Petrol tank breather
I think it vents high up in the filler cap neck
Sent from my Nexus 5 using Tapatalk
  • Chazg83
15 Feb 2014 15:17 #104592 by Chazg83
Replied by Chazg83 on topic Re:Petrol tank breather
mlines wrote: I think it vents high up in the filler cap neck
Sent from my Nexus 5 using Tapatalk[/quote
Cheers, so what you recon? Do you know off anybody that has made there's longer? Or had any trouble with water going in the tank?
15 Feb 2014 16:00 #104600 by facade
Replied by facade on topic Petrol tank breather
Depends on what you mean by a breather.
When the car is standing and the weather is warm (like it used to be in The Olden Days before it rained all the time) petrol evaporates. as more evaporates the pressure in the tank rises, until the one way valve in the top of the tank opens and allows the overpressure vapour to escape to the evap cannister, which absorbs the fumes. When you start the engine the evap cannister is vented to the manifold to suck the fumes into the engine.
(if you overfill the tank, the evap fills with liquid fuel and the car has a little trouble running until it clears the excess fuel)
As the engine runs fuel is used up and the tank starts to build up a negative pressure, and would eventually squash flat, so there is a vacuum relief valve in the filler cap that opens at a reasonable pressure difference.
At the MOT, the tester undoes the cap and listens for a shhhhhh as air rushes in to prove the cap is sealed.
The tank breather line goes from the top of the tank to the top of the filler hose, as the bottom of the hose is full of fuel, and you would never be able to fill the tank up if air can't get out of the top.
  • markyp2000
15 Feb 2014 18:38 - 15 Feb 2014 18:41 #104613 by markyp2000
Replied by markyp2000 on topic Petrol tank breather
At the mot the tester ie me dont listen for a shhhh it has nothing to do with the test all we test on the cap is the rubber seal dont matter is it shhhh or not
the tank has a air return pipe at the top of the tank to the top of the filler neck to let air out as you fill
iv never hurd a evap canistor filling with fuel seeing as thay are fitted higher than the tank
Your tank is sealed as long as the cap has a good seal trust me mine been sitting in water
At the pic posted of the fuel tank above there is no vent to air as its against the law that also why engines have brather pipes running to the intake system so it all gets burnt off
on moden cars
Last edit: 15 Feb 2014 18:41 by markyp2000.
  • Jutwit
15 Feb 2014 18:42 #104614 by Jutwit
Replied by Jutwit on topic Petrol tank breather
I thought the caps on all cars were the vented bit
Time to create page: 0.375 seconds
