waffle boards.
  • jonesyba420
08 Jan 2014 18:36 #99649 by jonesyba420
Replied by jonesyba420 on topic waffle boards.
GuardianAngel wrote: I have been advised to tie them to the back of the Jimny, so when you have got out of the hole, you can drag them along behind without having to stop.
Of course stopping means you run the risk of getting bogged down again.
good idea, length of rope long enough to reach from front to back with some carabiners on to hook them to the tie down points simples.
  • Decalwizard
08 Jan 2014 20:47 #99687 by Decalwizard
Replied by Decalwizard on topic waffle boards.
Mine are held on with the same type of ladder clamp and they never move an inch
jonesyba420 wrote: thats the thing i never know when i might pop out for abit of laning but dont want some d#*$ to steal them off my roof!!
yea it is cheap and they do cheaper ones which are not quite as long.
was thinking of using THESE and just cutting the thread down to just long enough, and maybe flatten the "wing nut" abit. id put the waffle boards next to each other with the clamps in between,then i can lock them on and less fiddly to get off when needed as its only 2 nuts to undo ;)
  • JerseyJimny
08 Jan 2014 21:03 #99695 by JerseyJimny
Replied by JerseyJimny on topic waffle boards.
I have Just got my set... £50 of ebay
At the moment they are just on my roof rack lashed down with a few bundges
  • GuardianAngel
08 Jan 2014 21:32 #99704 by GuardianAngel
Replied by GuardianAngel on topic waffle boards.
Just be careful with bungies. If you brake hard the inertia might make them shift around as the boards are quite heavy.
  • JerseyJimny
08 Jan 2014 21:34 #99707 by JerseyJimny
They seam pritty solid... Also the only way they can fall off is by going backwards.. I dont think the little Jim has the acceleration to do that! haha
08 Jan 2014 22:33 #99720 by kirkynut
Replied by kirkynut on topic waffle boards.
I understand how they will be held down now!
Jerseyjimny - just be careful the roughness of the waffle boards doesn't wear through the bungees.
Time to create page: 0.427 seconds
