235/75/15 on a 2" lift?
  • piprice
23 Nov 2013 22:02 #92849 by piprice
Replied by piprice on topic 235/75/15 on a 2" lift?
Is that metal? lol
On b&q looking for a 1mm mettle cutter :D
We have a industrial type grinder only with a 8 inch disc on its a beast lmao
Was going to mark up and mask off nearly and use a plastic jigsaw bit if they do them!
  • idiotmobil
23 Nov 2013 22:22 #92855 by idiotmobil
Replied by idiotmobil on topic 235/75/15 on a 2" lift?
I used a 10 inch on mine and made a neat job of it but im a master of the grinder
  • horam_jimny
23 Nov 2013 22:30 #92857 by horam_jimny
Replied by horam_jimny on topic 235/75/15 on a 2" lift?
RichiesJimny wrote: I fitted my 235's when I fitted my 3 inch lift (which lifted it 4 inches) and still needed to trim the arches slightly so you might struggle with a 2 inch lift but it probably also depends on tyre tread design and wheel offset.
The 235's do make quite a difference to the gearing you'll find it a lot slower on the road and you'll probably ride the clutch more off road.
this may sound stupid but why does the tyre width cause all these issues? Is it just down to the amount of rubber touching the ground and therefore increasing friction/grip?
I would have expected the tyre height (the 75 aspect of the 235/75/R15) to cause problems as it would increase the overall circumfrence and so affect gearing etc.
  • piprice
23 Nov 2013 23:05 #92862 by piprice
I were told 215/75/15 is the most to go before effecting gearing etc, so far so good!
  • piprice
23 Nov 2013 23:06 #92863 by piprice
Kickback comes to mind? Lol
idiotmobil wrote: I used a 10 inch on mine and made a neat job of it but im a master of the grinder
  • Leathery1
23 Nov 2013 23:22 #92870 by Leathery1
Replied by Leathery1 on topic 235/75/15 on a 2" lift?
recently fitted 215/75/15 has made speedo spot on, acceleration for overtaking non existent and top speed not much different cos it depends on balls not gearing in a Jimny! 3" lift (actually 4" difference) means nothing catches but I bet 235s on a 2" lift will grind like mad. Not in to trimming, it looks good as it is!
