235/75/15 on a 2" lift?
  • Docmartin4x4
23 Nov 2013 17:48 - 23 Nov 2013 17:49 #92777 by Docmartin4x4
235/75/15 on a 2" lift? was created by Docmartin4x4
Is the above wishful thinking? Will i need a body lift as well?
Mine is a 06 plate.
Also with those tyres on how is this going to effect ratio's?
Mart
Last edit: 23 Nov 2013 17:49 by Docmartin4x4. Reason: extra question
  • RichiesJimny
23 Nov 2013 18:52 #92792 by RichiesJimny
Replied by RichiesJimny on topic 235/75/15 on a 2" lift?
I fitted my 235's when I fitted my 3 inch lift (which lifted it 4 inches) and still needed to trim the arches slightly so you might struggle with a 2 inch lift but it probably also depends on tyre tread design and wheel offset.
The 235's do make quite a difference to the gearing you'll find it a lot slower on the road and you'll probably ride the clutch more off road.
  • idiotmobil
23 Nov 2013 18:56 #92794 by idiotmobil
Replied by idiotmobil on topic 235/75/15 on a 2" lift?
I had them with 2" and trimming and it was fine but burned out a clutch in no time and gearing was terrible till I forked out for a rocklobster get some good smaller tyres the lift and it will do surprisingly well
  • Wiltec17
23 Nov 2013 20:39 #92816 by Wiltec17
Replied by Wiltec17 on topic 235/75/15 on a 2" lift?
My cousin has 2" lift, 235/75. On std rims and spacers, it scrubs on the road when turning. Had to trim front bumper, and the rear of the arch, we havnt tried it off road yet as it hasn't been trimmed enough yet.
I'm running a 3" lift and only had to trim the back of the arch, so far no scrubbing at all. :)
  • piprice
23 Nov 2013 20:58 #92826 by piprice
Replied by piprice on topic 235/75/15 on a 2" lift?
Pppfffffttt lol I'm having great difficulty with mine!
Fitted 215/75/15 today with a 2 inch suspension lift and on certain lock I'm cAtching like crazy!
I've no alternative but to trim tomorrow with a jigsaw :s
  • steffan
23 Nov 2013 21:50 #92845 by steffan
Replied by steffan on topic 235/75/15 on a 2" lift?
Don't use a jigsaw use a 4 inch grinder with a 1mm mettle cutting disc in you will get a much better cut
Time to create page: 0.168 seconds
