Liana engine transfer is it worth it
  • supergaz
07 Nov 2013 09:33 #89758 by supergaz
Replied by supergaz on topic Liana engine transfer is it worth it
Also have new inlet and outlet gaskets ready. I also got a new oil pickup pipe and new sump pan which is not that expensive from suzuki.
  • jonesyba420
07 Nov 2013 09:36 #89760 by jonesyba420
Replied by jonesyba420 on topic Liana engine transfer is it worth it
So basically you just need the 1.6 engine from the liana and everything else you need is already on the current 1.3? Does the ecu need swapping over or will the jimny one adapt itself to the new engine?
are the engine mounts the same?
does the 1.6 mate straight to the jimny gearbox?
  • gaz3359
07 Nov 2013 09:43 #89761 by gaz3359
Replied by gaz3359 on topic Liana engine transfer is it worth it
jonesyba420 wrote: So basically you just need the 1.6 engine from the liana and everything else you need is already on the current 1.3? Does the ecu need swapping over or will the jimny one adapt itself to the new engine?
Yes
No just the injectors ecu adapts
Use the jimny engine mounts the holes are there on the 1.6 block
Yes again
i bought a full liana for £225 with tax and test ran it for 2 weeks made sure engine was ok then did the swap,i just used the 1.3 manifold gaskets with them been metal,gave the inlet one a smere of sealant.
Scrapped remains of the car got £110 back
sold the cats for £50
ive got someone wanting the 1.3 out the jimny so once thats gone will have only cost me my time
Did mine on the cheap obviously.the engine i put in was on roughly 110,000 from memory and its sweet as a nut impression im getting is the m series is very reliable.
  • Jimnyboy2b
07 Nov 2013 11:28 #89766 by Jimnyboy2b
Replied by Jimnyboy2b on topic Liana engine transfer is it worth it
Iv got a a 2001 jimny what year lianna will go best. For the injectors does it need updating or somthing on the 1.3 ecu
  • Jimnyboy2b
07 Nov 2013 11:35 #89767 by Jimnyboy2b
Would you say mpg was beta with a 1.6
  • RichiesJimny
07 Nov 2013 12:37 #89771 by RichiesJimny
Replied by RichiesJimny on topic Liana engine transfer is it worth it
Any year liana will be fine as they are all none are vvt, just use the 1.6 injectors and the ecu can cope with no problems.
Mine seems better on fuel now as you don't need to work the engine as hard.
NOTE jimnys with a 1.3 vvt CAN'T use the liana engine.
Time to create page: 0.282 seconds
