Liana engine transfer is it worth it
- Licksan
07 Nov 2013 18:33 #89819
by Licksan
When you say it "copes" what are the pitfalls on using the standard Jimny ECU? Does it need remapping? Is that possible to do with the standard ECU or would a piggy back be required?
I want to do the swap but don't want to find it just runs.... I want it to run properly with correct AFR, timing etc so it's producing full power with no lumpy idle or rough spots in the rev range.
Replied by Licksan on topic Liana engine transfer is it worth it
Rhinoman wrote:
Jimnyboy2b wrote: Iv got a a 2001 jimny what year lianna will go best. For the injectors does it need updating or somthing on the 1.3 ecu
That was quick - three hours ago you were just looking!
The Liana engine will only fit Jimnys with an M13 engine so you need to check which engine you have. The 1.3 ECU isn't ideal but it copes, you need the Liana injectors.
- Sponnie
07 Nov 2013 19:04 #89826
by Sponnie
Replied by Sponnie on topic Re:Liana engine transfer is it worth it
Good question.
Sent from my C6903 using Tapatalk
- gaz3359
07 Nov 2013 19:06 #89827
by gaz3359
Replied by gaz3359 on topic Liana engine transfer is it worth it
Ive had mine in since july ish and done a few mile,runs spot on,no lumpy idle,better on fuel than the 1.3,no fault codes have cropped up,doesnt have to be revved as hard and if you give it a bootfull 70 comes round quite quickly.
Ive done a couple of jobs on a friends jimny today and its just running the 1.3 i forgot how sluggish they are especially under 4k.
- Sponnie
07 Nov 2013 19:07 #89828
by Sponnie
Any particular year LIANA or year jimny gearbox?
- supergaz
07 Nov 2013 19:15 #89832
by supergaz
Replied by supergaz on topic Re:Liana engine transfer is it worth it
With the Liana just remember VVT or Non VVT. All the M16a engines are the same otherwise.
M13a = M16a
M13a VVT = M16a VVT
M13a = M16a
M13a VVT = M16a VVT
07 Nov 2013 19:17 - 07 Nov 2013 19:19 #89833
by j999pre
You could still go baleno or grand vitara g16
Grey pick up Jimny
Replied by j999pre on topic Liana engine transfer is it worth it
piprice wrote: I can only assume mines a g13b? 2002 O2 model?
Timing belt and Sohc.
Am i out of the equation?
Grey pick up Jimny
Last edit: 07 Nov 2013 19:19 by j999pre.
Time to create page: 0.812 seconds
