Liana engine transfer is it worth it
  • Jimnyboy2b
07 Nov 2013 07:45 #89742 by Jimnyboy2b
Liana engine transfer is it worth it was created by Jimnyboy2b
Hi looking to buy jimny Iv owned few Sjs and Sammy want try it's younger brother. I want to up rate the engine first then go from the lift wise and gearing. Is the engine change easy.?
  • jonesyba420
07 Nov 2013 08:20 #89748 by jonesyba420
Replied by jonesyba420 on topic Liana engine transfer is it worth it
Have been thinking about this myself. Can someone put a list up of the things you need to fit a 1.6 liana engine in a 2002 dohc jimny?
  • Jimnyboy2b
07 Nov 2013 09:01 #89750 by Jimnyboy2b
Replied by Jimnyboy2b on topic Liana engine transfer is it worth it
Yer I thought I get my info off this site as the builds on here are really good want to do things right the once and once only.
  • gaz3359
07 Nov 2013 09:18 #89752 by gaz3359
Replied by gaz3359 on topic Liana engine transfer is it worth it
Done it to mine difference is night and day
the only things i bought when i swapped mine was and oil filter,oil,and the stud/threded part the oil filter screws on to.
Every thing swapped off the 1.3
Rocker cover,dip stick
sump
oil pick up
flywheel clutch
bottom pully
use liana injectors
Those are the main parts,i swapped the alt and power steering brackets over aswell but its supprising how many parts are the same.took me a couple of days on and off obviously it was a few month ago now so may have missed the odd thing.
  • supergaz
07 Nov 2013 09:25 #89753 by supergaz
Replied by supergaz on topic Liana engine transfer is it worth it
The jimny should have come from the factory with the 1.6! Well worth the swap.
  • gaz3359
07 Nov 2013 09:26 #89754 by gaz3359
supergaz wrote: The jimny should have come from the factory with the 1.6! Well worth the swap.
exactly the words i said after doing it !
Time to create page: 0.198 seconds
