double din radio trim for later Jimnys??
  • Al.
19 Jul 2015 09:17 - 19 Jul 2015 09:22 #147974 by Al.
Ok a quick update from me.
I originaly ordered this Connects2 CT23 Double Din Facia Plate for Suzuki Jimny and I did not like the way it worked, you have to fit the radio to the facia plate, and insert everything in one go.
Next option was the Suzuki plate, my local dealer ordered both for me to try, and at the same time found out that the suzuki fitting kit is not longer available.
I ended up using this 73821-76J00-5PK panel. the unit is set back a bit more than I like, but it the best option I've found so far, I used the original Suzuki bracket to mount the unit, it worked fine.
Speakers, I placed 10cm in the front, and 13cm in the rear, these fitted in perfectly.
[IMG
Last edit: 19 Jul 2015 09:22 by Al..
  • JimnyGlenn
31 Jul 2015 12:27 #148765 by JimnyGlenn
Replied by JimnyGlenn on topic double din radio trim for later Jimnys??
Al. wrote: Ok a quick update from me.
Al, when you said you used the original Suzuki bracket. What did you mean? The brackets from the original Suzuki radio?
  • JimnyGlenn
31 Jul 2015 21:32 #148787 by JimnyGlenn
Rhinoman wrote:
gilburton wrote: I'm not really after a super dooper sound system as the jimny doesn't really lend itself because of the noise compared with a car but I wanted to upgrade to an SD slot and other connectivity and possibly a sat nav.
The modern units bring all this together as the Jimny is a bit limited on free dashboard space and you end up with wires and gadgets all over the place.
That's why I bought mine really, I had an older double-DIN in my van and after that the stock Jimny head unit seemed very limited. I bought this one:
www.aliexpress.com/item/6-2-In-Dash-2-Di...ation/736346336.html
its a good unit but it isn't a good size, the trims that you can buy for them just don't work in the Jimny. I haven't managed to sort that yet, I've got used to the gaps now but I'll probably have another go at it once the weather improves.
Did you manage to sort the gaps Rhinoman? I was going to buy a unit that seemed to fit in the original hole but apparently it has limited functions. Started to do my head in now :( I really want one like you have fitted with all the gadgets on but I am fussy, especially with it being a brand new car, the gaps would not do any good for my OCD lol.
  • NineCherries
01 Aug 2015 11:00 #148798 by NineCherries
Replied by NineCherries on topic double din radio trim for later Jimnys??
Have a look at my post on page 3 (143364) the pioneer is a nice unit (best if you have an iPhone though, but the do a similar unit designed for android auto now) nice fit and gives me loads of features including sat nav
