Jimny crankshaft pulley repair?
  • Orangeherald
10 Apr 2014 14:00 #111816 by Orangeherald
Replied by Orangeherald on topic Jimny crankshaft pulley repair?
Another update. 20k miles, still running fine. I have a suspicion it will go on now until the whole car dies!
  • Orangeherald
25 Feb 2017 13:14 #178500 by Orangeherald
Final report on the repaired pulley. While checking I spotted I needed a new alternator belt. Watching the pulley at tickover I saw it was running ever so slightly out of true. Time to replace it. On removal I noted that two of the welds had fractured. It was still complete and felt solid so failure was not going to be fast and catastrophic. I assume the very slight mismatch between hole diameter and pins allowed enough movement to fracture the welds eventually, but the pins remained in situ. It lasted 45000 miles, no problems noted. However the new pulley runs a little quieter. An interesting experiment, but I would only recommend it as a temporary repair until a new pulley could be fitted. The new one is not the genuine Suzuki, but a German made one. The rubber layer seems neater and thinner. Time will tell if it lasts as well or better than the factory part!
  • mickt
26 Feb 2017 19:26 #178565 by mickt
Replied by mickt on topic Jimny crankshaft pulley repair?
Brilliant experiment and well engineered. And thanks for the updates. But I believe this only proves that a flexible pulley is needed and it is there as a sacrificial item to save the crankshaft. It seems there is no set figure, time or use for the failings and sometimes the only indication is a belt going or screaming or in some instances catastrophic failure, mostly without warning. At least the screaming belt gives you time to fix it prorerly!
  • Orangeherald
26 Feb 2017 21:22 #178573 by Orangeherald
Yes, thats what I reckon. I am sure that it was made with rubber in it for a reason. The G13B had a different design of pulley, without rubber I think. Did they learn something there, or is the later engine different in its behaviour? Who knows. I proved only that I got away with it for a long time, but maybe one day there would have been an expensive noise! If there is any useful lesson in this I suggest it is to watch the pulley at tickover now and then. If it starts to run sightly out of true, its time for a new one. Ignoring it will be more expensive.
27 Feb 2017 08:28 #178580 by mlines
  • mickt
27 Feb 2017 11:12 #178587 by mickt
That is correct. The G13BB is just a normal metal pulley. Obviously the M13A is a lot different even though they are nearly the same cc ( M 13A is 4cc bigger). The dual cam being the obvious visual difference but the crank design for some reason needed dynamic balance, at what is not known to the general public, rpm that makes the rotating mass unstable enough to cause vibration. A lot of gas turbine engines suffer the same in that there are certain rev ranges that are to be avoided to stabilise the eng at. Obviously they transit Ok through them but do not allow them to stabilise at in operation.
Time to create page: 0.721 seconds
