Jimny crankshaft pulley repair?
  • Orangeherald
27 Aug 2012 17:52 #46903 by Orangeherald
Replied by Orangeherald on topic Jimny crankshaft pulley repair?
You would need to drill and tap, and thats longer winded. Of course weld wont come loose either! ;)
  • Orangeherald
11 Oct 2012 22:17 #50044 by Orangeherald
Time for a report on how this modification is performing. Only one minor problem, and that was my fault. I did not do the bolt up tight enough on the pulley and it loosened a bit, allowing oil to leak past the seal. All tight and cleaned up now, and no other troubles. Up to now, 1200 miles covered. No vibration, no broken crankshaft or anything else. Pins intact and pulley still running true. Those miles were about 95% road work with a little 60-65mph, much at about 50 across country and some town work. The rest has been around a farm, along green lanes which have plenty of mud filled holes, and across stubble, so it has been tested in a variety of conditions.
  • Orangeherald
26 Jan 2013 22:24 #59776 by Orangeherald
Just a quick update. Nothing to report at all! Few thousand more miles and no problems, all still working as it should. I almost dare say this is a cure! :whistle:
  • Dave cc
26 Jan 2013 23:31 #59788 by Dave cc
Replied by Dave cc on topic Jimny crankshaft pulley repair?
Well done what no snapped crankshaft HaHa :laugh: we never used to have any of this crap years ago dual mass Harmonic crank dampers so why do we need it now just another way of screwing money out of you and more to go wrong
  • Orangeherald
29 Jan 2013 17:30 #60141 by Orangeherald
Bygones days of simplicity! Some things are better, no more carbs to go out of tune and balance, points to wear out, distributor caps to fail etc. But my old mate who has just spent a fortune getting a solid flywheel in his Rav4 so it goes along again has another point of view!
Anyway, I am sure some other bit of built in obsolescence will get me, but so far so good. :P
  • Orangeherald
22 Jun 2013 14:42 #74669 by Orangeherald
Nearly 10k miles, still working! ;)
Time to create page: 0.169 seconds
