Snorkel fitted!
- Bigchridy
myers647 wrote: yes i do think it is. some of the more expensive snorkel tops have a water run off it the head, but these safari type copies like the one i have fitted dosn't, so it turns round backwards and stops the water entering the air filter and engine??
Fair enough. I'll have to think about it then!
The head is shaped the same as the safari one fitted to my mates disco and has 4 slits in it that look like they would allow water to come out. I may be totally wrong. I guess I'll find out when we get some heavy rain! See the attached pic.
Attachment safari-snorkel-air-flow-500x500.jpg not found
Chris
- myers647
- Keefe
Bigchridy wrote:
Keefe wrote: I've got one of those 'other' snorks on my Jim.
Made out of GRP, very brittle. I liked them because they don't run down the wing but after fitting it, I've 'gone off' it!
If I thought that fitting one of these would cover the hole left in the wing, I would be ordering one now.
Mmmm!
Don't know if you can see what I mean from this picture?
Its hard to see where your snorkel enters the wing in that picture. Have you not got a side on picture?
It looks like your snorkel might enter the wing a bit lower down than where my snorkel would run. You could always fiberglass over the hole?
I was looking at getting the same snorkel you have but I had seen that someone on here (cant remember their name!) had put their jimny on its side and it cracked the snorkel. It kind of put me off but then I guess any snorkel can get damaged if you hit it hard enough or drag it along the side of a gulley.
Chris
I get a picture later and let you see.
I'm not bothered too much if the other snork doesn't cover the hole. I'd probably just 'pop rivet' an alloy plate behind the hole after 'tidying' it up.
Reaper, if you are interested in the snork, watch this space, it's not even connected up yet as Jim is not on the road for the moment, but if I do get one of these other ones, you can have first dibs.
K
- ShuDuck
¨Keefe wrote: I've got one of those 'other' snorks on my Jim.
Mmmm!
If I understand you correct, you no longer like this snorkel? is it because of the material?
this pic might help www.pirate4x4.no/forum/attachment.php?at...d=77236&d=1325106027
- Keefe
Yes, the material is on the brittle side. It looks fine when it's fitted but I don't think there is any 'give' whatsoever if you caught it on a wall, gate or tree trunk etc.
I had one of those TJM snorkels on my Mitsi Delica, I fitted that myself and it just felt so much 'softer' being made out of a 'textured', 'soft' plastic.
Mind you, it was nearly 3x the price by the time I received it from Oz!
We shall see what happens, got loads of other stuff going on at the moment, a new hobby, my old hobby and not knowing if I will have a job after July!
Thanks for the picture as well.
K
- Keefe
99.90 eu
10.00 eu
+18% tax (Es) 19.78 eu
129.68 eu total.
Which is 107.76 GBP
Any import tax/fees?
If that is right, I'm having one.
It's nearly half the price I paid for the shorty snork, once you've added VAT & p&p costs on!
Nice find! You ought to be on commission!
Keith
