standard jimny wading depth
09 Dec 2011 00:02 #27603
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Replied by ooky_123 on topic Re: standard jimny wading depth
Ive taken a standard Jimny up to the bottom of the windscreen without a snorkel, and had no water ingress.
The current Jimny has also been swimming with water over the lights for a prolonged period with no issues either.
With the snorkel fitted, Ive taken my jimny up to the middle of the mirrors.
- happypig
09 Dec 2011 02:52 #27605
by happypig
Did you get water ingress into the cabin ?
Replied by happypig on topic Re: standard jimny wading depth
ooky_123 wrote: With the snorkel fitted, Ive taken my jimny up to the middle of the mirrors.
09 Dec 2011 08:05 #27610
by facade
Replied by facade on topic Re: standard jimny wading depth
If you go deeper than about 8" the swivel housings fill with water and you can kiss the swivel bearings goodbye. :huh:
- wanderinstar
09 Dec 2011 09:19 #27614
by wanderinstar
Replied by wanderinstar on topic Re: standard jimny wading depth
One thing I don't understand about Jimny's and deep water. OK you can put a snorkel on to get air into the engine. But noone has mentioned waterproofing the electrics. It is a petrol engine after all. Are they waterproofed from new.Mind you I have been using diesel cars for qiuet a few years now.Possibly all petrol engines are noe indifferent to water.
Pray tell please.
Ian.
Pray tell please.
Ian.
09 Dec 2011 09:26 #27615
Replied by mlines on topic Re: standard jimny wading depth
They are better than a lot of petrol cars because the high voltage electrics are under a cover on top of the engine. Whilst the cover is not waterproof (in fact it is open at the back) it does provide an element of protection that means the engine keeps turning in a lot of situations where other petrol engines will have stopped.
- wanderinstar
09 Dec 2011 09:39 #27616
by wanderinstar
Cheers Martin.Would there be any advantage in sealing this box, or is it open at the back for a reason (cooling).
Your extended diff breathers don't seem to be all that long. Would they not benefit from being longer or is there some sort of device in them that seals it when under water. Am thinking of the old snorkel you used to use when swimming that had a ping pong ball in the top.
Time to create page: 0.153 seconds
