A maddening knocking
- NineCherries
27 Aug 2015 20:57 #150800
by NineCherries
Replied by NineCherries on topic A maddening knocking
Would it be worthwhile removing the shock for a short run? If the shock is off and the noise is still there then it's not the shock.
27 Aug 2015 23:39 #150813
I guess I need to bite the bullet and get me hands dirty. So yes.
Replied by helijohn on topic A maddening knocking
NineCherries wrote: Would it be worthwhile removing the shock for a short run? If the shock is off and the noise is still there then it's not the shock.
- Thank you received: 1988
28 Aug 2015 05:20 #150817
Replied by Lambert on topic A maddening knocking
Had this problem on the terios. 2 new dampers and that particular noise went away to be replaced by the same at the front, two more dampers and a pair of top mounts and we got about 3 months before the front anti roll bar links have started to knock like a bas tard. Expensive but worth it for not going mad.
29 Aug 2015 18:45 #150930
I took the shockers off today........took ages
cos I reckon they were on when it was built in 1997.......and then decided not to drive it as it was bouncing like a funny ball at the slightest touch. :ohmy: Sooooo I put them back but swapped them and turned them through 180° as well. Also I thoroughly cleaned the fittings, threads etc. in case I have to return to this soon. Guess what.............the knocking has gone!! Go figure. :whistle:
29 Aug 2015 21:29 #150941
Replied by Daniel30 on topic A maddening knocking
Fantastic well done!!!
bet you'll miss it now :woohoo:
29 Aug 2015 21:58 #150944
I wonder how long the "fix" will last. It is amazing how quiet the motor is now that the constant rattling has stopped. I now realise it was a tiring noise.
Daniel30 wrote: Fantastic well done!!!
