A maddening knocking
  • helijohn
17 Jun 2015 20:02 #146166 by helijohn
A maddening knocking was created by helijohn
Which seems to be the back door catch or maybe the hinges. It sounds just like a door rattling (reminds me of a window in a house rattling in the wind) but I can't think of a way of checking if it is the door other than taking the bugger right off. :(
I've tried checking the door for float on the hinges but they have no slack at all. I've tried adjusting the striker plate right up...........no use.
18 Jun 2015 06:43 #146195 by j999pre
Replied by j999pre on topic A maddening knocking
Could something be loose inside the door?
Grey pick up Jimny
  • helijohn
18 Jun 2015 15:03 #146215 by helijohn
Replied by helijohn on topic A maddening knocking
j999pre wrote: Could something be loose inside the door?
There is nowt in there to cause this sort of heavy sounding knock but I think it is worth taking the card right off and driving the motor.
  • helijohn
24 Jun 2015 08:11 #146505 by helijohn
Could it be a baffle in the exhaust box?? The exhaust has gotten more rorty in the last few months. I have to admit my first thought was that the exhaust box was banging against the chassis - it is that sort of sound.
24 Jun 2015 14:24 #146519 by Halford
Replied by Halford on topic A maddening knocking
stick a cushion between the door frame and the rear door then tie the door shut and make a short drive to listen for the knock.
will rule out the door catch and hinges at least and probably help you get closer to locating the sound source.
that's what I'd try anyway.
24 Jun 2015 14:49 - 24 Jun 2015 14:52 #146520 by Rhinoman
Replied by Rhinoman on topic A maddening knocking
A baffle is quite possible, have you checked underneath? I would think that a broken shock or similar would be more likely, my rear door doesn't close properly but it doesn't rattle.
Last edit: 24 Jun 2015 14:52 by Rhinoman.
