Trailmaster vs. Black Raptor
- Lasse
- Visitor
Trailmaster 50mm lift or Black raptor premium 50mm lift?
Or perhaps a third brand!
- Thank you received: 305
Trailmaster is reviewed well and recognised as a quality kit.
AVO adjustable dampers +50mm and Eibach prolift +30mm springs with 15mm seats on my car and very happy.
sniper
- Lasse
- Visitor
Ups forgot to add that it for the Gen 4 ! Hehe
- Thank you received: 168
Personally I will be getting the Black Raptor kit, just waiting for things to return to normal a bit more first however.
- Thank you received: 1761
- Thank you received: 479
Trailmaster are a well established and well respected company that have been making their own products to a very high standard for a number of years. They are fully type approved. I've never heard a bad word about them.
Black Raptor first came to my attention a few years ago with some badly aligned stickers stuck on some generic shocks. They don't have a website. Their name is very similar to an existing 4x4 parts brand, but they aren't associated in any way. Very little information is available about their products or the brand.
Which will perform better? I have no idea, but I know where I'd rather spend my money.
- Lasse
- Visitor
But am i right that when you see the Jimny From a side view it look like the front is sits lower than back when fitted with the Trailmaster 50mm kit..
Must say I’m going for the slight raised look rather the ultimate flex..!
I believe Black Raptor is Jimnybits kit. At least that is what they told me. They shocks they spec from a shock maker and kit is built to their design/spec.Busta wrote: My 2 pence worth...
82cm rear arch to ground
79cm front arch to ground
98cm door handle base to ground (probably 97.5cm after reviewing the video again)
After lift (which has not been published yet)
87cm rear arch to ground = +50mm
83.5cm front arch to ground = +45mm
102cm door handle base to ground = +45mm (as corrected above).
If the wheel arch measurements are correct and the front and rear wheel arches are lined up, then it is 3cm lower at the front in its unmodified version anyway
- Thank you received: 923
"Black Raptor" Is indeed a JimnyBits brand... RLP (Russell Lee Palmer) Engineering / 4x4 Outlet... all one and the same...
- Lasse
- Visitor
