  • topjimny
03 Mar 2012 22:52 #34774 by topjimny
Hi Monkey,
My Jimny is a 2009 vvt black, like yours. I'm into fitting bigger tires. Where can i buy that 20% reduction gears? It will fit my almost "showroom" Jimny? This might be cheaper than a full swap into a non-vvt or sj's... It will be perfect for my little pocket! And what tire size do you recommend? (sorry for my poor english)
Cheers
  • Monkey
04 Mar 2012 04:07 - 05 Mar 2012 06:43 #34777 by Monkey
Hi Topjimny,
The gears can be purchased from a supplier of special Jimny gearsets. They replace 2 of the original gears in the transfer case, so yes they will fit your "showroom" jimny. Cost wise, you could do the SJ swap for around the same price as the TJ gears, of you know where to get the SJ parts cheap ;)
Tyre's, if you got the 20% gears i would recommend 30x9.5 r15.
Last edit: 05 Mar 2012 06:43 by mlines. Reason: Legal reasons
04 Mar 2012 16:19 - 04 Mar 2012 16:47 #34818 by dirtydogz
lt's time to get out and do some wheeling :woohoo: before you spend any more $$$$$$$$$$$ mate.:dry:
Attachment canstock44833451_2012-03-04.jpg not found
Keep up the good work.;)
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 04 Mar 2012 16:47 by dirtydogz.
  • topjimny
05 Mar 2012 01:22 #34871 by topjimny
Good point! But it's hard to find a good one here where i live! Specially the old one (without chain).
Thanks again for the info! Your Jimny is pure inspiration! Also like the DIY stuff! Trying to solve the gears now since i just found some cheap 31's. Just created a new post outside yours!
cheers,
Thiago
  • Monkey
05 Mar 2012 04:39 #34872 by Monkey
topjimny wrote: Good point! But it's hard to find a good one here where i live! Specially the old one (without chain).
cheers,
Thiago
Thanks mate! :)
Gearing late model jimny's is not a cheap exercise :(
  • Monkey
05 Mar 2012 04:40 #34873 by Monkey
dirtydogz wrote: lt's time to get out and do some wheeling :woohoo: before you spend any more $$$$$$$$$$$ mate.:dry:
Bwahaha thanks!
Only 8 day's til the rear locker's goes in ;) Pics to come from today's wheeling sesh....
Time to create page: 0.254 seconds
