Vacuum Hub bolts
05 Feb 2021 20:11 #232516
by Scimike
Replied by Scimike on topic Vacuum Hub bolts
Yes 12.9 is a higher spec than 8.8 and can take a higher torque. You also need to check if they are metric fine or course. If in doubt just visit a local engineering supplier and show them the offending item, they are usually very helpful and cheaper than eBay etc.
- X8GGY
05 Feb 2021 20:24 #232517
Replied by X8GGY on topic Vacuum Hub bolts
They are indeed "normal" M8 thread bolts, as "we" supply with spacer rings (to fit SJ hubs) etc...
I hate to disagree with Scimike, but from experience I'd go with 8.8s... 12.9s are more inclined to sheer... I once blew all 6 free wheel hub bolts on my old Vitara with twin LSDs, an SJ crawler box and a Centreforce (on/off!) clutch rescuing a Land Rover at Tom's Farm back in the day... I'd also reference the Diesel Brother's episode where they built the Diesel Helipcoter, they also found that 12.9s were more serceptible to sheer than 8.8s which are a bit more maluable than brittle...
05 Feb 2021 21:40 - 05 Feb 2021 21:41 #232518
by Scimike
No problem being disagreed with, just playing it safe and simply going by the torque figures quoted for 8.8 and 12.9, the latter being about 45NM which is closer to the Suzuki figure quoted by Ray. I personally don't understand why they are so tight.
Havefun
Havefun
Last edit: 05 Feb 2021 21:41 by Scimike.
05 Feb 2021 21:56 #232519
by Busta
Replied by Busta on topic Vacuum Hub bolts
They don't just hold the hub on. They transmit all the drive from the axle to the wheel.. M8x1.25, 40mm length. I have replaced mine wth socket cap (allen key) bolts to do away with the obscure E10 bolt head.
The following user(s) said Thank You: Scimike
05 Feb 2021 22:14 #232520
by Scimike
Ah ok, that will be why I suppose. I need to take a closer look the next time I have them apart.
TaMike
TaMike
- RayPaterson
05 Feb 2021 22:31 #232521
by RayPaterson
Replied by RayPaterson on topic Vacuum Hub bolts
Hi, If I understand right, you sell the bolts? I was going to replace both sets of not too expensive.
Ray
Ray
Time to create page: 0.424 seconds
