Re:Re:Well that didn't last long
08 Jul 2020 04:31 #224670
by Old Neil
Replied by Old Neil on topic Re:Re:Well that didn't last long
Jimny running normal again with out fixing anything?
- Thank you received: 1999
08 Jul 2020 05:07 #224671
Replied by Lambert on topic Re:Re:Well that didn't last long
The other alternative is that the catalytic converter is disintegrating/partially blocked?
- Reason2doubt
08 Jul 2020 07:14 #224672
by Reason2doubt
Replied by Reason2doubt on topic Re:Re:Well that didn't last long
As Lambert says try the catalytic converter.
Mine was very blocked and the garage ran Cat cleaner through it to pass it - did improve throttle response and generally calmed the car down a bit (not as jumpy on the rpms). Maybe a bit of redex in the fuel and give it a blast up the motorway?
08 Jul 2020 09:44 #224679
by Old Neil
Replied by Old Neil on topic Re:Re:Re:Well that didn't last long
Thanks, might be getting to the bottom of it found a mechanic who would put a code reader on jimny with out charging a fortune
Sounds like it's code 21 TPS voltage high/abnormal
Still got to track down New TPS to confirm
I'll let you know what happens
Time to create page: 0.241 seconds
