Re:Re:Well that didn't last long
06 Jul 2020 11:03 #224580
by Old Neil
Well that didn't last long was created by Old Neil
Driving back from work jimny didn't feel like it had the same power, changing gear revs stayed over 3 grand then slowly reduced, when it was stationary in neutral rev at a gand then drops almost stalls then back up again?
- Thank you received: 1998
06 Jul 2020 16:05 #224600
Replied by Lambert on topic Well that didn't last long
Probably cam and or crank sensor. Easy enough to do bu try and get them from a reputable supplier as there are increasing numbers of fakes about.
06 Jul 2020 21:52 #224612
by Old Neil
I've had intermittent electric folt since I've owned it?
Replied by Old Neil on topic Re:Well that didn't last long
Hi Lambert, got cam sensor while back from Brian at suzistore(that is were i got the brake booster)G13BB doesn't have crank sensor, don't know why it's all set up to fit one?Lambert wrote: Probably cam and or crank sensor. Easy enough to do bu try and get them from a reputable supplier as there are increasing numbers of fakes about.
07 Jul 2020 04:46 #224619
Replied by Lambert on topic Re:Well that didn't last long
Ok so next suggestion would be coils and leads.
07 Jul 2020 09:41 #224634
by Old Neil
On the way to work at lights idling it go 1000rpm then almost stalls, driving at 90kmh it would speed up with out moving accelerater pedal
Replied by Old Neil on topic Re:Re:Well that didn't last long
Sorry new coils and leads (NGK)not that long ago, made a real differenceLambert wrote: Ok so next suggestion would be coils and leads.
07 Jul 2020 13:33 #224649
by Old Neil
Were can i down load manual early jimny with G13BB, i had one but it was on my computer that doesn't work, I'm not that computer savie
Thanks
Thanks
Time to create page: 0.365 seconds
