Re:Re:Well that didn't last long
06 Jul 2020 11:03 #224580 by Old Neil
Driving back from work jimny didn't feel like it had the same power, changing gear revs stayed over 3 grand then slowly reduced, when it was stationary in neutral rev at a gand then drops almost stalls then back up again?
06 Jul 2020 16:05 #224600 by Lambert
Replied by Lambert on topic Well that didn't last long
Probably cam and or crank sensor. Easy enough to do bu try and get them from a reputable supplier as there are increasing numbers of fakes about.
06 Jul 2020 21:52 #224612 by Old Neil
Lambert wrote: Probably cam and or crank sensor. Easy enough to do bu try and get them from a reputable supplier as there are increasing numbers of fakes about.
Hi Lambert, got cam sensor while back from Brian at suzistore(that is were i got the brake booster)G13BB doesn't have crank sensor, don't know why it's all set up to fit one?
I've had intermittent electric folt since I've owned it?
07 Jul 2020 04:46 #224619 by Lambert
Ok so next suggestion would be coils and leads.
07 Jul 2020 09:41 #224634 by Old Neil
Lambert wrote: Ok so next suggestion would be coils and leads.
Sorry new coils and leads (NGK)not that long ago, made a real difference
On the way to work at lights idling it go 1000rpm then almost stalls, driving at 90kmh it would speed up with out moving accelerater pedal
07 Jul 2020 13:33 #224649 by Old Neil
Were can i down load manual early jimny with G13BB, i had one but it was on my computer that doesn't work, I'm not that computer savie
Thanks
Time to create page: 3.871 seconds
