Bearing retainer creep
18 May 2019 20:30 #208291
Bearing retainer creep was created by mlines
Having thought my rear bearings have failed (both!) I took them off tonight.
Neither bearing felt worn but both move on the shaft "in and out". It looks like the retainer has moved back,
Has anyone experienced this?
It almost looks as if I could nip it back up tight in a press, however I think it is probably damaged so I will replace. Is there a way to stop this creep?
- Thank you received: 1897
18 May 2019 21:00 #208293
Replied by Lambert on topic Bearing retainer creep
I have never done one myself yet but is it possible that the bearing or the ring weren't fully seated at installation or that there was a burr or other debris preventing them seating completely that has subsequently been dislodged? Od that it's both simultaneously? Were both retainers new, could it be a manufacturing issue that they are slightly oversized to grip the half shaft?
18 May 2019 21:09 - 18 May 2019 21:10 #208294
Replied by mlines on topic Bearing retainer creep
The bearings and retainers were changed at the same time so would have been from a similar batch from the supplier (and whilst one might have not pressed home properly I find two hard to believe. However I also changed to the 31" tyres so a considerable change in dynamics. Also, in the sandy south, bearings have a naturally short life so the shaft has had lots of retainers on it over the years, does it wear?
Last edit: 18 May 2019 21:10 by mlines.
18 May 2019 22:28 #208297
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Bearing retainer creep
Yes the shaft can wear. It is normally caused by bearing pick up and rotating the inner race.
Both the KAM rear shafts have suffered this on mine, (like it when i got it) due to lack of bearing changes. Hence my interest when you where talking about them reproducing some of there stuff.
18 May 2019 22:30 #208298
by Jezz
I should add, Thats just a google pic, Not mine.
19 May 2019 05:14 #208300
Would it be possible to get a circlip groove machined into the shaft to help locate the retainer? I know that it would act as a stress riser but it would also be a fuseable link to protect the diff?
Time to create page: 0.171 seconds
