31 10.50 15 tyres and correct wheel offset / width
03 Nov 2017 08:32 #185784 by Busta
Just to clarify, all the sizes I listed are '31s', as in they are 31 inches tall, so they will give you the clearance you require.
Regards the rim width, narrow rims are better for protecting the tyre bead and sidewalls. The sidewalls are so tall on off-road tyres you can, within reason, fit whatever width rims you want. I'd always choose offset rims rather than spacers. It's one less thing to give issues, saves a bit of weight and hassle and IMO the rims look nicer.
The following user(s) said Thank You: mlines, 1066Boy
03 Nov 2017 09:25 #185787 by mlines
X88RED wrote:
It seems however there is no definitive answer as to what offset or width works best with 31’s? Some say 7” wide and some say 8” wide and then some say 10”. Also same with the offset ha? Really not sure now!?
This is why I am so vague on tyres and rims when you called in for a chat ;)
It seems to me that even on apparently identical Jimnys some setups work on one and not the other. There seems to be little hard and fast rules.
Sounds like you are going for the same set up as my target as well
  • X88RED
03 Nov 2017 15:05 #185790 by X88RED
Ok so I am swaying more towards 750 r16 or 235/85 r16 now ha - thank you everyone!
What width wheels and offset would work best with these tyres? Also what ratio of transfer box would be the absolute best here?
I have spoken to Rockwatt and he still thinks 5:1 but I would like to gain other peoples opinions and real world experiences!
Thank you!
03 Nov 2017 15:31 #185791 by mlines
Well my 235/85 R16 should turn up on Tuesday next week if you want a look.
I also spoke with Rockwatt and he says 5:1 but I have the old 4:1 still in so I might try running on that until my bank account recovers.
  • X88RED
03 Nov 2017 15:50 #185794 by X88RED
That would be very handy Martin! What offset/ width are the Vitara wheels you are fitting?
I take it you run uprated shafts and cv's?
03 Nov 2017 16:28 #185795 by Lambert
As a general rule the wheels ought to be about 70 percent of the width of the tyre. In practice anywhere between 5 and a half and 6 and a half should be fine.
Time to create page: 3.067 seconds
