Front hub compatibility and rear full float axle query
- lammurai
26 Apr 2017 19:57 #180626
by lammurai
Replied by lammurai on topic Front hub compatibility and rear full float axle query
Those are solid hubs of a samurai/vitara/grand vitara
- TomDK
26 Apr 2017 20:07 #180627
by TomDK
Replied by TomDK on topic Front hub compatibility and rear full float axle query
Are you sure about that?
Samurai and Vitara's comes with manual freewheel hubs.
- lammurai
26 Apr 2017 20:24 #180630
by lammurai
Had several samurais and vitaras with fixed hubs.
Maybe it's different in Holland
26 Apr 2017 20:36 #180632
by kirkynut
Replied by kirkynut on topic Front hub compatibility and rear full float axle query
SJ's and Vitaras came with fixed hubs but free wheeling hubs were an option many chose to save fuel.
I have fixed hubs on the front of my Jimny.
- stimpy
26 Apr 2017 22:00 #180637
by stimpy
Replied by stimpy on topic Front hub compatibility and rear full float axle query
So, can anyone confirm my original query so i can hopefully take some information from this!?
"My Jimny is a 51 non ABS car and i've seen some 2004 abs hubs. Are these compatible?"
Thanks...
Thanks...
27 Apr 2017 06:23 #180641
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Front hub compatibility and rear full float axle query
Yes the hubs with the wheel bearing will fit. There is a difference in brake disc centre bore on some abs Jimnys. I think from 2005 on but you would need to check. Also you would need to check the abs chop ring doesn't foul anything.
Then decide whether you want to use fixed hub locking plates as pictured from an sj, or manual ones like the Aisin type. With these you will need spacers to fit them. Or you can use Jimny specific ones such as avm
Grey pick up Jimny
Time to create page: 0.297 seconds
