Front hub compatibility and rear full float axle query
  • stimpy
27 Apr 2017 19:16 #180653 by stimpy
j999pre wrote: Yes the hubs with the wheel bearing will fit. There is a difference in brake disc centre bore on some abs Jimnys. I think from 2005 on but you would need to check. Also you would need to check the abs chop ring doesn't foul anything.
Then decide whether you want to use fixed hub locking plates as pictured from an sj, or manual ones like the Aisin type. With these you will need spacers to fit them. Or you can use Jimny specific ones such as avm
Thank you!
I will be using Aisin units as i have some anyway...
Time to create page: 0.209 seconds
