Damd Dw, feel like setting it on fire grrrr.
- Justin83
03 Apr 2017 06:05 #179862
by Justin83
Replied by Justin83 on topic Re:Damd Dw, feel like setting it on fire grrrr.
I read a post the other day where a guy welded some snall box section too his, sorted it pretty well apparently.
So the bushes will likely be a waist of time?
Need Martin to chime in, I've pm'd him.
It's such a ball ache, gonna go ahead and do arb bushes and drop links + panhard bushes next.
- DINGLE287
03 Apr 2017 09:59 #179864
by DINGLE287
Replied by DINGLE287 on topic Re:Damd Dw, feel like setting it on fire grrrr.
That's the kind of links I'm thinking of. Either making from scratch with stronger tube or bracing original 1 to strengthen. I've gotta take mine off and see if it's repairable first. Need to make room for it at work and just strip the while front Inc king pins etc I think
Sent from my SM-N9005 using Tapatalk
- DINGLE287
03 Apr 2017 10:01 #179865
by DINGLE287
* lines I'm thinking of
- Justin83
03 Apr 2017 13:31 #179869
by Justin83
Right I've now got super pro panhard and antiroll bar bushes, new drop links, and later 2009 on radius arm to chassis bushes coming... and the said offending oil seal.
Any tips on fitting the bushes?
03 Apr 2017 17:27 #179875
panhard & ARB bushes are easy with some threaded rod and some various size sockets.
The radius arms are a really big press (30T +) or drill out the rubber and cut the metal band out with a hacksaw. not easy and takes ages. I think there was something about doing this in the big jimny blog. the new ones will need a press if standard (mine are polybushes and in 2 parts so no press needed).
Riccy
Replied by Riccy on topic Re:Damd Dw, feel like setting it on fire grrrr.
Justin83 wrote: Right I've now got super pro panhard and antiroll bar bushes, new drop links, and later 2009 on radius arm to chassis bushes coming... and the said offending oil seal.
Riccy
- Justin83
05 Apr 2017 18:45 #179935
by Justin83
Cheers pal, maybe a garage job for those then....
Just fitted the panhard bushes and new oil seal, also removed some shims to make it just one at the bottom to see if there was too much preloaded causing it...
Still dangerous to brake from 50mph.
Running out of options here now.
Not sure whether to get the wheel bearings done as I've read they are very hard to diagnose and people have fixed death wobble by Changing them even tho they felt fine...
Dreading having the radius arm out, awkward as it's our only car had enough now uuuurgh.
Snapped a king pin nut earlier but thankfully i was able to cut a groove in it with my dremel and it can out with a screwdriver!!!
Time to create page: 0.149 seconds
