Stereo system. Cheap and cheerful 4.1 setup
27 Feb 2017 17:26 #178610
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Stereo system. Cheap and cheerful 4.1 setup
Nice,
Whereabouts is it located? I have a dog guard on my jimny and plan to put my sub just behind one of the seats. The plan was to have the amp mounted on the dog guard behind the opposite seat.
27 Feb 2017 17:28 - 27 Feb 2017 17:29 #178611
Replied by Daniel30 on topic Stereo system. Cheap and cheerful 4.1 setup
mine is in my boot, i still use my back seats thats why i had to trim it down a bit to fit
Last edit: 27 Feb 2017 17:29 by Daniel30.
27 Feb 2017 17:36 #178615
by Mike G
ah ok.
I'm going to hold off buying anything just now until I do a bit more research. I think I have some old stereo kit from the 90's kicking around somewhere. I might see if I can dig that out, if it works I'm laughing.
27 Feb 2017 17:39 #178618
Yeah a bit of retro kit is always a better bet
27 Feb 2017 17:50 #178623
by Mike G
Everyone likes free
28 Feb 2017 08:39 #178650
by Busta
Replied by Busta on topic Stereo system. Cheap and cheerful 4.1 setup
The quality of that ebay kit looks dubious. Lots of stuff for your money, and I'm sure it's noisy, but that's not always best.
If you want a nice sounding system, get a pair of quality components speakers (£50 ish) for the front with remote tweeters that you can mount higher up on the dash (rather than firing the sound into your shoes). A small active sub like Daniel's (or there is plenty of room under the seats for an under-seat sub) will provide sufficient bass and take some load off the small front speakers. Don't worry about fitting rear speakers. Instead, if you want more volume consider a 2 channel amplifier to run the front speakers, which will have a lot more oomph than the tiny amplifier in the headunit itself.
Bear in mind that fewer speakers of higher quality will always produce a better sound than lots of cheap ones. I've tried all sorts of systems- stripping out entire interiors to fit dozens of speakers, amps and making up MDF boot installs, but after doing all that the I've learnt the simple systems always sound the best. In small cars I would always go for a 2.1 and concentrate on quality speakers driven by quality amps.
Time to create page: 0.170 seconds
