Squealing Like a Pig!
- Venter
13 Oct 2016 10:20 #173473
by Venter
Replied by Venter on topic Squealing Like a Pig!
Sounds like some likely candidates there, especially since a flick of the key gets rid of the sound. Might mean that the component (PS / water pump etc) is temporarily deactivated, hence sound temporarily disappearing. Will check it out asap
- mickt
13 Oct 2016 12:34 #173479
by mickt
Replied by mickt on topic Squealing Like a Pig!
Especially as the belts shredded perhaps the water pump bearing is not running true!
16 Oct 2016 05:17 #173591
by kirkynut
Replied by kirkynut on topic Squealing Like a Pig!
Sounds like the belts slipping still to me. Have you tightened them enough?
- Venter
16 Oct 2016 19:59 #173628
by Venter
Will also look into the belts, definite possibility there. When I replaved last belts, seem to remember the new belts weren't same spec as handbook recommends, but memey is fuzzy on that one.
Been squealing really bad today in the heavy rain (NE Scotland). Wonder if that is further ammo for the belts theory...
17 Oct 2016 20:51 #173672
by Busta
Replied by Busta on topic Squealing Like a Pig!
Belts sound very likely if they are screeching on startup. A correctly tensioned belt should not screech! There is enough adjustment to allow some different belt lengths to work but obviously there is a limit.
Also check the bearing in the tensioner on the power steering belt. They get dry and screech/squeel, but are easily pressed out and replaced. The bearing is a standard size, available from your local bearing shop.
- Venter
17 Oct 2016 21:24 #173673
by Venter
Thanks Busta
Now just to find the time...
Time to create page: 0.772 seconds
