T-Max OUTBACK 12V 9000 lbs Winch problems
  • atnas666
22 Feb 2016 18:30 #162817 by atnas666
Replied by atnas666 on topic T-Max OUTBACK 12V 9000 lbs Winch problems
Ah now this I will try.. if I can find the book for what terminals are what lol
  • TomDK
22 Feb 2016 18:41 #162818 by TomDK
Replied by TomDK on topic T-Max OUTBACK 12V 9000 lbs Winch problems
Easy :-)
The A terminal is the one that is by itself. Usually at the brush end of the motor :-)
  • atnas666
22 Feb 2016 18:43 #162819 by atnas666
All wires on one side.
3 on top 1red 1yellow 1black
1 under 1black I
If I remember rite from fitting
  • TomDK
22 Feb 2016 19:20 #162824 by TomDK
Colors are not really important on this one. Just make sure you have a negative lead on the bottom terminal. Rest gives itself pretty much.
  • atnas666
22 Feb 2016 19:23 #162825 by atnas666
TomDK wrote: Colors are not really important on this one. Just make sure you have a negative lead on the bottom terminal. Rest gives itself pretty much.
ok thanks for the help
So to sum it up black terminal bottom jump lead to negative battery.
and red top jumped to either yellow top or black top
  • TomDK
22 Feb 2016 19:28 #162827 by TomDK
As I wrote.
Don't know anything about the colors. Negative lead to bottom connection which is ground. And two positive connections to the top. One for A terminal and for for either of the two F terminals.
